Old 20-07-2006, 10:03 PM   #1 (permalink)
The Devil's Advocate
iMav's Avatar
Default webcam required
could some1 please suggest me a good webcam and the price also .... thanx
http://beingmanan.com
iMav is offline
Old 20-07-2006, 10:42 PM   #2 (permalink)
bukaida's Avatar
Default Re: webcam required
Go for creative. Will cost u around Rs.800 to 900. Has a good motion detector feature.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 20-07-2006, 10:59 PM   #3 (permalink)
dont go for creative.....
go for logitech......and one more thing...always opt for CCD lens ..dont think of CMOS.......
mkmkmk is offline
Old 20-07-2006, 11:00 PM   #4 (permalink)
iMav's Avatar
2 posts 2 conflicting views ........
iMav is offline
Old 20-07-2006, 11:08 PM   #5 (permalink)
bukaida's Avatar
Add more sugar and it will be more sweet. Logitech are good but atleast double costly. When you get all the features under a reputated brand at much lower price then--
bukaida is offline
Old 20-07-2006, 11:09 PM   #6 (permalink)
iMav's Avatar
then what????? .... i chked the 2 latest logitech cams the fusion and the quick cam 5000 both are awesome in features but are around 5k each
iMav is offline
Old 20-07-2006, 11:15 PM   #7 (permalink)
bukaida's Avatar
It depends for what purpose you are using it. If you want to substitute your handycam with webcam, go for high end cams.If you want to use it for chatting, a low end cam will do. Also the most important thing is your budget.
bukaida is offline
Old 20-07-2006, 11:31 PM   #8 (permalink)
iMav's Avatar
budget i will be able shell around 2k .... purpose is for internet usage only
iMav is offline
Old 20-07-2006, 11:36 PM   #9 (permalink)
bukaida's Avatar
You will get good webcam at that price. Go to both creative and Logitech website and always select a model with motion detection capability.Check the price with your local dealer.Always insist on bill and warrenty.
bukaida is offline
Old 20-07-2006, 11:53 PM   #10 (permalink)
iMav's Avatar
thank u for ur assistance
iMav is offline
Old 21-07-2006, 08:50 AM   #11 (permalink)
i have logitech webcam and its givin me decent performance....
i bought it for around 2K....
who the hack is this??
mukul is offline
Old 21-07-2006, 09:22 AM   #12 (permalink)
go_gamez's Avatar
i was gifted with a I ball -Robo.468..looks very nice (almost a robot )..but i dont know about its features..does anyone have the ROBO-468 ??how is its performance ??cauz ive never used my webcam till now...
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
