Old 20-07-2006, 07:22 AM   #1 (permalink)
tweety_bird_bunny's Avatar
Default remotely connect to my pc
i have a laptop and pc.....both running xp pro sp1....i connect them thru cross over cable...is there any way that i can control the acttions of my pc thru my laptop....
i mean to say that i can c in real time the desktop of my pc frm laptop and control the actions of my pc.....
is there any software or way of doin it?
tweety_bird_bunny is offline
Old 20-07-2006, 07:38 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: remotely connect to my pc
Yes.. Its called remote desktop. Its built into windows XP its in accessories somewhere. Go through the help ans support center to know more about it.
kalpik is offline
Old 20-07-2006, 12:21 PM   #3 (permalink)
JGuru's Avatar
Yes, you can control your PC running XP using your laptop. Checkout this Microsoft
link for the precise solution:
http://www.microsoft.com/windowsxp/u...y/default.mspx
JGuru is offline
Old 20-07-2006, 11:11 PM   #4 (permalink)
bukaida's Avatar
You can use third party softwares like PCAnywhere for greater features.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 21-07-2006, 02:06 AM   #5 (permalink)
PrinceHeart's Avatar
Didn't anyone think of Netmeeting ?? I have used it before. It works great. But dunno about how much more features anyone would want. If your PC and lappie is on network, u can virtually change anything on any node. If netmeeting is used, then you can share the desktop and can use your lappie to access the PC anytime right ?
*PrInCe*
PrinceHeart is offline
