Old 20-07-2006, 06:17 AM   #1 (permalink)
Default Command Prompt Help
Hi...
Whenever I try the commands like Netstat, Ipconfig in command or cmd I get an error like:-
'Netstat' is not recognised as an internal or external command,operable program or bach file.
These commands run in the RUN dialog...but close automtically after a few seconds.
Please can someone solve this...
rishi1 is offline
Old 20-07-2006, 06:35 AM   #2 (permalink)
Laptoping
Sourabh's Avatar
Default Re: Command Prompt Help
As for the window closing immediately, first go to the command prompt via cmd on run menu and then give the commands.
If you face that error, it would probably coz you dont have administrator privileges.
Sourabh is offline
Old 20-07-2006, 11:05 AM   #3 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
there seems something wrong with ur path. check 'c:>path'
Rollercoaster is offline
