Old 19-07-2006, 02:58 AM   #1 (permalink)
Unhappy Help Needed
Hi
I am planning to buy a headphone. However i am strapped for cash. Ive got only abt 400 bucks. Know that i wont get good quality but which one will give me the best of the lot. (Intex, TEch com, Front tech, I ball........) App if i can get a reply within one day
and thank you in advance
Dragoniteid2 is offline
Old 19-07-2006, 07:29 AM   #2 (permalink)
SNIST Screamer !!
vijay_7287's Avatar
Default Re: Help Needed
the ones from Intex , TechComm, and Fronttech will cost u less than 200 bucks ... all are almost same ... just make sure the built in mike works properly ... tht wont really rock anyway !!!
and this might help
Suggest a Headphone
vijay_7287 is offline
