Old 19-07-2006, 12:35 AM   #1 (permalink)
Default max payne won't run katanka mod
heloo guys and galz, i have a pirated version of max payne 1 and i download the katanka mod for max payne along with it the mod developers asked me to download the max payne patch 1.5 to run the game so i installed the patch and then mod , but now the game asks me for the original cd of max payne 1, what to do???
can some one help me???
previously this did not happen coz the max payne was cracked and was designed to run from the hard drive itself, but tyi issue started after he installation of the path 1.50....
any ideas as to what i should be doing?????
If A is success in life, then A equals x plus y plus z. Work is x; y is play; and z is keeping your mouth shut.
rockerboy is offline
Old 19-07-2006, 02:35 AM   #2 (permalink)
thunderbird.117
Posts: n/a
Default Re: max payne won't run katanka mod
See BOLD. Buy a original copy and then you can play the game.
See you.
Old 19-07-2006, 06:14 AM   #3 (permalink)
18 Till I Die............
If you indulge in piracy you won't get any help here
You have 2 choices
- Go and buy original game
- Ask somewhere else for help
http://www.bash.org/?258908
mehulved is offline
