Old 18-07-2006, 08:53 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Default which ups to buy n price??
currently i hav datavision ups....but it doesnt wrk properly...there occurs sometimes short circuting in its sockets...
so wanna buy new ups...
shud i go for intex???
my budget is approx 2000...
plz suggest
tweety_bird_bunny is offline
Old 18-07-2006, 09:10 PM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: which ups to buy n price??
Go for APC ups.. 500VA for around 2100 bucks.. Its the best UPS there is!
kalpik is offline
Old 18-07-2006, 11:53 PM   #3 (permalink)
knight17's Avatar
I also reccomends APC it is really good abt Rs2000/-
You will get s/w monitering etc with that...
Go for APC
knight17 is offline
Old 19-07-2006, 02:47 PM   #4 (permalink)
PrinceHeart's Avatar
I got STAR 500VA - old one.
Now that since i have upgraded to 17 in flat monitor, whenever there is power cuts - the USP makes beeps and shuts down. It doesn't even give me anytime to save my works. If I have to shutdown windows, I have to switch off the monitor, then the USP works for few minutes - before i can click windows button on keyboard and try to shutdown - memorising like click win button - then click UP button . then click ENTER, then click RIGHT arrow to select SHUTDOWN and click ENTER to shutdown the PC.
I think i have to get a new UPS - which can support 17 in monitors.
help me out.
Thanks
*PrInCe*
PrinceHeart is offline
Old 19-07-2006, 04:52 PM   #5 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Hey Kalpik .. Its only Rs. 1950 now .. I bought one in june for a friend
I have APC Back-UPS ES 650Y-IN at home .. Its good
Comes with the Software n Datacable for auto shutdown in case of power failure
n u arent at desk
rollcage is offline
Old 19-07-2006, 07:28 PM   #6 (permalink)
kalpik's Avatar
How much did the ES 650Y-IN cost you?
kalpik is offline
Old 19-07-2006, 08:44 PM   #7 (permalink)
bukaida's Avatar
@ princeheart
You can go for a 1000VA UPS which will be ideal to support large monitors and
high wattege SMPS. Microtech 1000VA(although not the best) is a decent performer in the low budget range.
Desktop: P-IV 2.4GHz, 512MB DDR, 865GBF Mother Board,
G-Force 5200FX, 17" Samsung flat, WinXp with SP2,
Kaspersky Internet Security 2009.
Laptop:LENOVO 3000 C100 D7 lappy with 2GB DDR2.
bukaida is offline
Old 19-07-2006, 11:35 PM   #8 (permalink)
Thx for the info bukaida - can u tell me the price of Microtech 1000VA and if its not the best - what is and what price ?
thx
*PrInCe*
Old 20-07-2006, 12:19 AM   #9 (permalink)
Brave_Hunt's Avatar
I'm using UPS called "Perfect" I can tell you It's very perfect and It rocks. It'll cost you around Rs. 1,800-2,200. But I'll suggest you to get "Matrix" have no jist about the price but It's the best one.
And well said, E=MC˛ And there's a light!
Brave_Hunt is offline
Old 20-07-2006, 01:21 AM   #10 (permalink)
I tried yahoo search for "microtech" and "perfect", but no good result. Are they local brands ? I had heard about APC many times before. Does they got 1000VA UPS ? I got no idea about all this stuffs. With my present PC config, all i want is when the power goes off, my UPS should be give me atleast 10 mins to save my running programs/files before shutdown to avoid hardware/software problems which is bad news for PC's health.
Anyone with more infos ??
thx
*PrInCe*
Old 20-07-2006, 07:41 AM   #11 (permalink)
kalpik's Avatar
Yes APC does have a lot of models. Check out http://www.apcc.com/
kalpik is offline
Old 20-07-2006, 01:56 PM   #12 (permalink)
bukaida's Avatar
well prince heart , the spelling they are using is MICROTEK. It is quite old and reputated company not a local one.Google it .
bukaida is offline
Old 20-07-2006, 02:06 PM   #13 (permalink)
From what i heard APC is a good company for these UPS types..
Sorry for the spelling mistake for Microtek, I will surely have a look. And since Im planning to get my 2 CPU connected, i think i will be needing a better and advance UPS to keep those 2 CPU online anc connected.
Thx to all !!
btw.. the thx button is not showing today. does anyone knows what happened ?
cheerz
*PrInCe*
Old 20-07-2006, 03:52 PM   #14 (permalink)
Brave_Hunt's Avatar
I guess they've removed that function or else It doesn't appear on QnA section.
Old 21-07-2006, 04:49 PM   #15 (permalink)
shanket's Avatar
I think u should go for Su-Kam....
I have been using it for around 5 yrs.... But i hv faced no problems as such.....
shanket is offline
Old 21-07-2006, 07:02 PM   #16 (permalink)
Well i asked my vendor to let me know about ACP with 1000VA. He will let me know in a couple of days.
I have seen ads on TV about Su-Kam.. I tried searching for its website ? Does they got any website at all. If yes - kindly post it here. Nothing wrong in taking notes before buying a good UPS.
thx
*PrInCe*
Old 22-07-2006, 08:29 AM   #17 (permalink)
rollcage's Avatar
Got It for Rs.2850 in may (dont know the current price)
Here is the website link - for UPS Products from APC (Choose India)
http://www.apcc.com/products/category.cfm?id=13
@PrinceHeart
Try for APC .. they are the best!
rollcage is offline
