Old 17-07-2006, 09:58 PM   #1 (permalink)
Exclamation which net connection should i take
hi friends i have hp dv5200tx laptop
considering option of mobility
1.reliance internet card(pcmcia port)
2.tata indicom internet card(pcmcia port)
3.reliance mobile which also gives internet
4.share internet broad band connection with my friends in hostel
tanmay_rajvanshi is offline
Old 17-07-2006, 10:14 PM   #2 (permalink)
gooby pls
Third Eye's Avatar
Default Re: which net connection should i take
you choose-mtnl(the best),reliance,airtel
don't choose-tata,bsnl dataone
Third Eye is online now
Old 17-07-2006, 10:18 PM   #3 (permalink)
The Frozen Nova
casanova's Avatar
1 & 3 & 4 will do.
Dont go Tata. If ur use is limited, go for the 4th option else 1st
Sify and airtel are a good alternative
www.nerdweed.blogspot.com
casanova is offline
Old 17-07-2006, 10:19 PM   #4 (permalink)
mostwanted
Posts: n/a
Exclamation good connection
Tata is quite good im happy with ih.But whatever u do dont go 4 sify its the worst
Old 18-07-2006, 12:27 AM   #5 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Go for bsnl dataone...Its the best and cheapest available
rakeshishere is offline
Old 20-10-2006, 12:09 AM   #6 (permalink)
hailgautam's Avatar
Tata indicom is worst. I had horrible experience with tata. I use BSNL which gives pretty good speeds. However airtel (broad band) has better plans such as starting from 9pm free usage; in bsnl it is 2.am in the morning.
hailgautam is offline
Old 20-10-2006, 12:26 AM   #7 (permalink)
Anindya's Avatar
Thumbs up Re: which net connection should i take
I use Reliance Netconnect from mobile. My plan is Freedom At Night. It gives u free surfing from 10pm to 6am the next morning. If u r planning to surf only and occational download then this option is not bad. I am satisfied with it. Check if this plan is available with u. I think one of the best advantage of using a net connection from a mobile is that U CAN SWITCH OFF OR CHANGE PLAN ANYTIME. JUST CALL THE CUSTOMER CARE. WHICH U CANT DO INCASE OF BSNL OR MTNL. I dont know about Sify or TataSky. GO FOR A MOBILE BASED CONNECTION.
www.techani.com
Latest post ->Take Ur Applications & Personal Settings With You
->Umpires Are Vampires
The Most Unknolegeble Parson. Plese Tech Me.
Anindya is offline
Old 20-10-2006, 04:57 AM   #8 (permalink)
For Delhi Users Mtnl Triband is the best.
jeetu is offline
Old 20-10-2006, 10:08 AM   #9 (permalink)
:-o
aakash_mishra's Avatar
You should go with 1 or 3
www.amiable.in
aakash_mishra is offline
Old 20-10-2006, 10:58 AM   #10 (permalink)
Welcome To The Jungle
sysfilez's Avatar
airtel is de best, in any case dont go for govt player.
Me n My Canon EOS 350D with EF 50mm f1.8
sysfilez is offline
Old 20-10-2006, 11:03 AM   #11 (permalink)
dude i thik u can go for mtnl dlink wire less conection if your use is limited in a particular range bu8t before u opt any schene see that u need to update your aptop every month and the update cmes to 20 mb per month
if u have an cell u can also take the unlimited scheme whihc is of 300rs of dolphin
hackers2005.3721 is offline
Old 16-07-2007, 01:34 PM   #12 (permalink)
Talking Re: which net connection should i take
thankx
Old 16-07-2007, 01:41 PM   #13 (permalink)
Resident Fanatic
Manshahia's Avatar
dataone 500 plan is not that bad...
Manshahia is offline
Old 16-07-2007, 04:07 PM   #14 (permalink)
gooby pls
Third Eye's Avatar
Originally Posted by tanmay_rajvanshi
thankx
Thank you for replying after one year.
Old 16-07-2007, 04:21 PM   #15 (permalink)
slugger's Avatar
freinds using Reliance PCMCIA card. have no complaints
buddy our friend here wants 2 surf on his lappy keeping option of mobility open. how on earth is he going 2 remain mobile with a dataone connection
OMG it soooo old. shud have checked it b4
btw tanmay wat took u sooo long 2 respond
slugger is offline
Old 16-07-2007, 04:26 PM   #16 (permalink)
Rebooting
Choto Cheeta's Avatar
I guess he took MTNL
U know its gov, so, took 2 months to apply, then 4 months to process then 4 months to deliver and Setup...
and he took 2 more months to test the connection to reply back
rebooting
ChotoCheeta.com
Choto Cheeta is offline
