Hi
I need some help with the following java script. I read in this months digit fast track that you can call a
js from html so that your source code will remain private. Can I do the same thing with this code? How can I do that? Can anyone tell me?
Please give me the source code of the html file using which I will be able to call this file.
<!-- TWO STEPS TO INSTALL MULTIPLE USERS:
1. Copy the first code into the HEAD of your HTML document
2. Put the last coding into the BODY of your HTML document -->
<!-- STEP ONE: Copy this code into the HEAD of your login HTML document -->
<HEAD>
<SCRIPT LANGUAGE="JavaScript">
<!-- This script and many more are available free online at -->
<!-- The JavaScript Source!!
http://javascript.internet.com -->
<!-- Begin
function Login(){
var done=0;
var username=document.login.username.value;
username=username.toLowerCase();
var password=document.login.password.value;
password=password.toLowerCase();
if (username=="member1" && password=="password1") { window.location="page1.html"; done=1; }
if (username=="member2" && password=="password2") { window.location="page2.html"; done=1; }
if (username=="member3" && password=="password3") { window.location="page3.html"; done=1; }
if (done==0) { alert("Invalid login!"); }
// End -->
</SCRIPT>
<!-- STEP TWO: Paste this code into the BODY of your HTML document -->
<BODY>
<center>
<form name=login>
<table width=225 border=1 cellpadding=3>
<tr><td colspan=2><center><font size="+2"><b>Members-Only Area!</b></font></center></td></tr>
<tr><td>Username:</td><td><input type=text name=username></td></tr>
<tr><td>Password:</td><td><input type=text name=password></td></tr>
<tr><td colspan=2 align=center><input type=button value="Login!" onClick="Login()"></td></tr>
</table>
</form>
</center>
<p><center>
<font face="arial, helvetica" size="-2">Free JavaScripts provided<br>
by <a href="http://javascriptsource.com">The JavaScript Source</a></font>
</center><p>
<!-- Script Size: 1.60 KB -->
Aditya
