Old 16-07-2006, 10:40 PM   #1 (permalink)
Question How can this be possible?
i mean 235 MB file in one 13 MB file
NagpurDaMunda is offline
Old 17-07-2006, 07:38 AM   #2 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Default Re: How can this be possible?
Why not? Lots of file types are compressible to a large extent! I even have a 14 MB file that extracts to 2.5 GB!
kalpik is offline
Old 17-07-2006, 07:48 AM   #3 (permalink)
eagle_y2j's Avatar
GTA sans Cd extracts 4.56GB of data!
Registered LINUX USER #438929
eagle_y2j is offline
Old 17-07-2006, 09:37 AM   #4 (permalink)
pop143's Avatar
Talking Re: How can this be possible?
nothing is impossible..as impossible itself says i'm possible..hehehhhehehee..!!
pop143 is offline
Old 17-07-2006, 12:21 PM   #5 (permalink)
Rebooting
Choto Cheeta's Avatar
Coooool comment... writting it down...
rebooting
ChotoCheeta.com
Choto Cheeta is offline
Old 17-07-2006, 03:16 PM   #6 (permalink)
rahul_becks23's Avatar
u write all the comments u like,maybe a hobby.........
rahul_becks23 is offline
Old 17-07-2006, 09:34 PM   #7 (permalink)
MasterMind
killerz's Avatar
i got a 1.4 mb office 12 rar file which expands to 700 mb and took me 2 hrs to uuncompress it
NOTHING IS IMPOSSIBLE
killerz is offline
Old 17-07-2006, 10:22 PM   #8 (permalink)
i also wanna know how such large extent compression is done??
Old 18-07-2006, 07:52 AM   #9 (permalink)
kalpik's Avatar
See basically, the PDF you might have, would have consisted mostly of text with very few pictures. ASCII packs very well. If you really need to know how compression works, read up here: http://en.wikipedia.org/wiki/Data_compression
kalpik is offline
Old 18-07-2006, 09:18 PM   #10 (permalink)
Learner
Kniwor's Avatar
lol... i can give you a 4.8 gb in 29kb
Kniwor is offline
Old 18-07-2006, 09:45 PM   #11 (permalink)
Bewitched!
xenkatesh's Avatar
Exclamation Re: How can this be possible?
how man? kidding?
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 19-07-2006, 01:24 AM   #12 (permalink)
thats impossible budddy,he's just makin fun
Old 19-07-2006, 07:37 AM   #13 (permalink)
kalpik's Avatar
Actually thats possible! Just make a text file consisting of only a single char repeated billions of times, till the file size reaches 4.8 GB. Then try to compress it. It will have a *very* good compression ration. Such files are called decompression bombs.
kalpik is offline
Old 19-07-2006, 08:01 AM   #14 (permalink)
pop143's Avatar
Smile Re: How can this be possible?
so finally..
which is the best software and best method to compress afile..??
any tricks anybody know...cus u share plaz..??
bye
pop143 is offline
Old 19-07-2006, 03:28 PM   #15 (permalink)
WinRK always gives an 'out of memory' error when i try to compress a 500MB folder using PWCM.Can anyone help?
Old 19-07-2006, 09:03 PM   #16 (permalink)
Bewitched!
xenkatesh's Avatar
@Kalpik
That kind of compression i only possible with text files...
@rahul_becks23
u need a lot of ram atlest 512... by the way what is ur memory of RAM?
Old 19-07-2006, 10:29 PM   #17 (permalink)
Wise Old Crow
blueshift's Avatar
Never heard of 14MB decompressing to 2.5gb.
yes it is possible to compress largely. I use 7-zip btw.
http://twitter.com/blueshift155
blueshift is offline
Old 19-07-2006, 10:30 PM   #18 (permalink)
its 512MB RAM
