Hi Tango !
I might doubt you have gone wrong ! Let me give you a option of doing the one you want and mostly wht I do ....
Using CDs and DVDs without a drive
Virtual CD copies your CDs and DVDs to the hard drive of your PC or Server using highly efficient data compression techniques. The virtual CDs are then run in virtual CD drives which are automatically set up in Windows and have all the functions and features of physical CD drives.
Advantages of Virtual CD:
* Up to 23 virtual CD/DVD drives
* Up to 23 CDs/DVDs accessible at the same time
* High speed access to an unlimited number of CDs and DVDs
* 1:1 access to CD- or DVD-images stored in a network
CD/DVD data throughput at hard disc speed (200x CD-ROM)
* Accesstime up to 93% faster than a phys. CD-ROM drive
* Concurrent access of several computers to a CD/DVD image
Download :
http://www.virtualcd-online.com/vcddemoe.exe
More Info :
Download the applications and you know wht to do next ! So next time please do not copy dvd's as such ! Coz most of them don't work !
This is best application i have seen . Also older version v4.04 can be seen on old Digit CD !
Try tht and tell me if u landup somewhere !
Regards,
Vinay
[Edited Batty] Merged
