31-07-2004, 03:06 PM
restarting pc
hii guys .. i got a new problem .. (actully problem never leave me alone ,..)
my pc now has started rebooting by itself actully 2 times only !!!! i have win xp os and p4 1.6 cpu . can it b a virus ??? i just recently overclocked my pc to 1.68 ghz but then again make it 1.6 . and after restarting it gives me msg that windows has recovered from a serious error ..
i have norton 2003 ...
help...
31-07-2004, 11:59 PM
If you 're getting an error messages such that some process is terminated unexpectedly and the system got restarted, then this is the security flaw of windows XP exploited by a WORM.
To remove this, visit http://download.microsoft.com and www.symantec.com
01-08-2004, 03:50 PM
dont forget to patch it up by visitin windowsupdate site
No Mercy, No Limits.
01-08-2004, 03:59 PM
downloading it only then let me see what happen ....
01-08-2004, 04:26 PM
a msg will prolly show up wen it tries to reboot........wen its der......go to run an type cmd.......................den type shutdown-a
ittl stop da restart
den get a patch
Be AfrAiD oF DaTA LosS........
bE vErY aFrAid!!!!!!!
01-08-2004, 07:39 PM
Version 2.0
hmm first do this..
press windows button + pause/break
Go to advanced tab
Click on settings button under Setup and Recovery
uncheck auto restart on system failure
from next time it wont reboot..
it will show bluescreen with some numbers written on it..
paste that number here..
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
02-08-2004, 12:30 AM
Looks like some Infection. Install the Updates from MicroSoft Site .That
shuld solve it .
Keep
Zindagi Ek JUa..Kabhi..Jeet...Kabhi Haar.....
Byeeee
K.K
04-08-2004, 04:13 PM
ya i have done from property of my computer so that is not restarting now but after each start it gives me error that system has recoverd from the serious error..
05-08-2004, 12:16 AM
Version 2.0
and the error code you get is ?
- Deep Ganatra -
www.whoisdeep.com
05-08-2004, 12:55 AM
what is the error message you get. you can't be downloading the numerous patches for windows xp if you don' t know what error it is. post the error message.
28-02-2005, 03:49 PM
Even I'm having this same problem
I didnt try ur solution Yet..
i'll try it and let U know the Number..
01-03-2005, 01:50 PM
Just Do It
SYMPTOMS
If Windows XP restarts because of a serious error, the Windows Error Reporting tool prompts you to report the problem to Microsoft for troubleshooting purposes. Windows may prompt you to report this information every time that you restart the computer, even if no error occurred during the previous session. After this problem begins to occur, you are prompted to send the information after every restart, even if you do not send the information.
CAUSE
This problem occurs because after a Minidump file is written, the paging file continues to have a flag set that indicates that a Minidump file must be written.
RESOLUTION
To resolve this problem, obtain the latest service pack for Windows XP. You can use Automatic Updates or Windows Update to obtain Windows XP Service Pack 2 (SP2).
01-03-2005, 08:43 PM
y! i too agree with "achacko@dataone.in".
if it also doesn't solve ur problem then check it ur RAM. cz if Bus speed doesn't match then also it repeat the message n that is cz by pagefile fault.
so, if u try by macthing RAM speed with the main board or try it 400 Bus speed RAM. it hing it solve u r problem.
Hey I am cool..........
02-03-2005, 03:37 PM
as you have overclocked, make sure that your processor is not fuming!, overheating can trigger a shutdown process.
a month back i replaced my processor, then it started giving same sort of problem. i later forund that the heat sink was not fit properly. now it works fine.
u can check the processor temp in BIOS setup screen
Be not Thou far from me o Lord....o my strength....haste Thee to help me.
02-03-2005, 10:43 PM
so should I send the error Report??
02-03-2005, 10:45 PM
I get this Error Signature......
BCCode : a BCP1 : 00000000 BCP2 : 0000001F BCP3 : 00000001
BCP4 : 804F1407 OSVer : 5_1_2600 SP : 0_0 Product : 256_1
02-03-2005, 10:57 PM
Technoholik !!
No SP installed , install it if u can, that should solve your problem.
[Desktop]
[CPU] Intel C2D 2.4Ghz || [RAM] 2GB DDR2 || [VDU] Samsung P2370MS 23”|| [HDD] 500GB Seagate 7200RPM SATA || [OS] Mac OS X (Hackintosh)
[Laptop]
03-03-2005, 01:45 AM
ARE U USING IE6?
IF YES THEN DID U GET AN ERROR MESSAGE?
IF YES THEN U HAVE BEEN ATTACKED BY A SPYWARE. USE SOME ANTI-SPYWARE SOFTWARE TO REMOVE IT & NEXT TIME WHEN SURFING USE A PROPER FIREWALL.
05-03-2005, 01:19 AM
#19 (permalink)
SUJ_ENGICO U R A BABY IN ALL THIS COMP STUFF> DONT GIVE USELESS ANSWERS!
ITS NOTHING ABT IE AND SPYWARE
Ish Karo... Ishq karna Tumhara Paidaishi Haq Hai........
Magar Kyon Na Is Bar Watan Ki Mitti Ko Mashuka bana le!!!
:) http://www.aseemn.org
05-03-2005, 02:57 PM
#20 (permalink)
Just Do It
u shud reinstall the Sp again, i dont think u've installed tht properly.....
And u shud send a repot too
Search this Thread |
