Under rs 5000.. amazing device...
Grand Hand View ( VGA TO TV ) or( PC to TV )
Compact size , 1280x1024 max resolution. Plug & Play
Grand Hand View is a handed-size universal VGA to TV converter box. It supports resolution up to 1280x1024* 60Hz. Compact size, Power from USB port, easy for carry. It is best for PC GAME, PC DVD, Internet viewing on TV, Entertainment, Education and Presentation.
Application
Entertainment - Play VCD and DVD movies on TV. Experience PC games on TV.
Presentations- Ideal for both classrooms and conference rooms
Documentation - Capture PC images on video tape.
Training - Easy software training via video tape.
Specification
Pure hardware design, just Plug & Display
No software driver requirement, compatible with any operation system
Support 640x480@60/72/75/85Hz, 800x600@60/72/75/85Hz, 1024x768@60/75/85Hz, 1280x1024@60Hz display mode.
Support Composite VIDEO output, S-VIDEO output.
Simultaneous display on VGA monitor and TV
Power from USB port
Supports IBM PC and MAC G4.
Supports one of the following system : NTSC(US/Taiwan), NTSC(JAPAN),PAL,PAL-M,PAL-N system.
Support overscan and underscan function.
Dimension : 110 x 56 x 36 ( mm )
Mode and Resolution Table
This converter supports the following VGA ( IBM PC) display modes:
Resolution 640 x 480 800 x 600 1024 x 768 1280x1024
Vertical Frequency(Hz) 60,72, 75,85 60,72,75,85 60,70,75,85 60
This converter supports the following MAC G4 display modes:
Resolution 640 x 480 832 x 624
Vertical Frequency(Hz) 66 75
System Requirement
Desktop or Laptop Computer with HD15 Pin VGA standard connection.
