Old 13-07-2006, 07:25 PM   #1 (permalink)
Default help needed urgently,pc hanging,pls help
hi guys im in gr8 prob
my pc is hanging right from bios ,this is going on for 2 days .i dont know wats prob,if it gets on then it hang on while running any prog on xp.
all in all my pc is juz hanging whether it be on bios ,if it gets forward from that then it hangs on further processes.
can any1 tell me wat do i do now ..
pls help
%% my site--
%% www.gmastermind.moved.in
%% my blog--
%% www.gmastermind.moved.in/wordpress
gycapri is offline
Old 13-07-2006, 10:08 PM   #2 (permalink)
String Phreak
mediator's Avatar
Default Re: help needed urgently,pc hanging,pls help
It cud be ur power problem,ide connector.....check power supply first!
mediator is offline
Old 13-07-2006, 10:36 PM   #3 (permalink)
gooby pls
Third Eye's Avatar
check the ram.reinstall it by removing.
Third Eye is online now
