i HAVE A 200 GB HDD. WITH INTEL P4 2.8GHZ PROCESSER.
THE PARTITIONS ARE AS FOLLOWS:
10 GB(PRIMARY) C:
30 GB D:
50 GB E:
50 GB F:
50 GB G:
I USE WINDOWS XP. WHEN EVER I FROMAT THE C: AND INSTALL THE WINDOWS XP AGAIN. WHILE INSTALLING, THE AREA IN WHICH THE SETUP ASKS THE DRIVE IN WHICH THE INSTALLATION IS TO BE MADE SHOWS 50 GB AS UNALLOCATED.
IF I CONTINUE THE SETUP INSTALLS THE XP SUCCESSFULLY AND THEN THE COMPUTER SHOWS THE 50 GB ( G : ) AS UNALLOCATED.
I TRIED TO RE CREATE THE PARTITION FROM THE DISK MANAGEMENT. BUT THE SAME THING HAPPENS WHEN I RE INSTALL THE OS.
PLEASE HELP ME
[/b]
