13-07-2006, 06:00 PM
HELP AND SUPPORT
Unable to open .chm files:Plz help
From 2 days i am getting this error msg while opening any help file of any s/w or while opening any e-book...I dont know the possible reason but can any1 here tell me the solution for it
See the image below:
.chm problem
14-07-2006, 12:14 AM
Re: Unable to open .chm files:Plz help
copy the files on the desktop and then try
14-07-2006, 02:29 AM
Is that stored in Network Drive?
14-07-2006, 02:51 AM
Wise Old Crow
or your Help executable file must have been corrupted. Check for the file hh.exe and replace it with another.
14-07-2006, 11:21 AM
Seems it is on a network drive. Try copying it to some local directory and start it.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
14-07-2006, 01:58 PM
HELP AND SUPPORT
well watz the file hh.exe ..where can i find it and replace it
i tried copying it everywhere --desktop,local directory,cd rom...I get the same error
i tried using some converters like chm 2 pdf and chm 2 word ...They are unable to open the file itself...they give a msg some what like " CONTENT FILE DOES NOT EXIST"...I cant figure out the possible reason for this and i need a solution for this as i have some 35 ebooks with me which are in chm format...I havnt read them coz of this problem
Reason: Automerged Doublepost
14-07-2006, 03:21 PM
Wise Old Crow
hh.exe file is in the Windows directory if you are using WinXP. If you want, I will send a copy of my file to you.
Are you getting this problem now or you could open the file in past? Do you download those files using ftp??
14-07-2006, 03:47 PM
HELP AND SUPPORT
I found it c:/windows directory using the inbuilt search tool of xp but now there is one more problem..i go to start--->and click Help and support..It doesnt open..I tried a lot of times but it doesnt ...
I went to run and typed services.msc and checked whether the help and support service is stopped but to my surprise it was on...I stopped and restarted it but didnt help...So i cant figure out what exactly has happened
14-07-2006, 04:15 PM
Wise Old Crow
Seems like your whole Windows may be under attack. lol
Do you use Sp2?
First reset all your settings in IE.(Restore to defaults). Theres a file helpctr.exe in WINDOWS\PCHEALTH\HELPCTR\Binaries folder. Chk if it runs from there.
14-07-2006, 05:23 PM
Did you try if the problem was with this file only or with other files too.
try opening this file on someone else's PC. maybe the file is corrupt
14-07-2006, 07:12 PM
HELP AND SUPPORT
It opens in my father's office comp and my friend's comp but not in mine
Do you use Sp2?
I use winxp pro sp2 edition...and the file helpctr.exe u said is not opening
14-07-2006, 10:04 PM
Wise Old Crow
If it opens in others pc then there is high possibility that your files are corrupt. Probably this may be due to sp2. Did you installed any kind of theme or patch like Autppatcher/Vista theme?
If your friend is having XP, then you can copy hh.exe and helpctr.exe from his pc or just ask me.
15-07-2006, 01:15 PM
HELP AND SUPPORT
I once used Vista transformation pack but i uninstalled it coz it gave me some problems just after 2 days of its use...As u said i replaced both the files hh.exe and helpctr.exe with a new one but i have the same problem...Now coz of this just dont hint me reinstall the whole ****ing OS
15-07-2006, 08:32 PM
Wise Old Crow
Do you have WindowsXp hotfix 896358 installed? Uninstall it if you have.
If there is a file named hh.dat in \Documents and Settings\%username%\Application Data\Microsoft\HTML Help, delete it. Note its a hidden directory.
Check the registry if it works.
#For Help and support:
In Registry Editor, goto HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\Curr entVersion\App Paths\HELPCTR.EXE
If the key isn't there, right click and create a new key HELPCTR.EXE
It should have a value of C:\WINDOWS\PCHealth\HelpCtr\Binaries\HelpCtr.exe
Restart your pc.
#For chm files:
Goto HKEY_CLASSES_ROOT\chm.file\shell\open\command
The Default value for this entry should be: "C:\WINDOWS\hh.exe" %1
Next, go to: HKEY_CLASSES_ROOT\.chm
The Default value for this entry should be: chm.file
if none of the entries exist then create a new one.
Following link will be of help to you:
http://www.help-info.de/en/Help_Info...hh_command.htm
http://twitter.com/blueshift155
15-07-2006, 09:27 PM
HELP AND SUPPORT
i uninstalled the hotfix which u said ...
but i dint find the file hh.dat which u said me to find in the directory \Documents and Settings\%username%\Application Data\Microsoft\HTML Help,
I saw that it was not hidden... and i checked the registry as u said ...and all was fine and nothing to be edited
16-07-2006, 12:49 AM
Wise Old Crow
Originally Posted by sakumar79
The file hhctrl.ocx like they said, is actually in the system32 folder.
17-07-2006, 01:27 AM
HELP AND SUPPORT
The version of my hhctrl.ocx is 5.2.3790.2453 and i have IE-7 beta 3 installed so what am i supposed to do..
The microsoft website said----- "If a different version of Internet Explorer is installed, extract a new copy of Hhctrl.ocx from the Hhupd.cab file on the Internet Explorer CD, or install the latest update for Windows HTML Help"
So i updated my windows help..It didnt help me at all
17-07-2006, 06:35 AM
#19 (permalink)
Did you register the dll file as mentioned in the link I provided in the earlier post?
Run "regsvr c:\windows\system\hhctrl.ocx"
Arun
17-07-2006, 10:38 AM
#20 (permalink)
are there any special characters in the filename or path ???
I had a folder called "C#" where I had some ebooks. I was unable to open any.
When I changed the name from "C#" to "C Sharp" , I could open them
17-07-2006, 05:19 PM
#21 (permalink)
HELP AND SUPPORT
Arun
when trying to register the dll file i get a msg that "cannot find the dll file hhctrl.ocx"
17-07-2006, 09:21 PM
#22 (permalink)
Then, locate the file and revise the command to show correct path... If it is in system32 folder, run "regsvr c:\windows\system32\hhctrl.ocx"
Arun
20-07-2006, 05:34 PM
#23 (permalink)
HELP AND SUPPORT
Arun
I tried but i get a new error something like this:
LoadLibrary("c:\windows\system32\hhctrl.ocx") failed.
24-07-2006, 06:43 PM
#24 (permalink)
Rubik's Uncle!!
I had a .chm file , but it was not showing the contents  , i tried a few softwares but none was able to fix it , after i saw your post it worked  , thanks royal for the trick  .
24-07-2006, 09:50 PM
#25 (permalink)
HELP AND SUPPORT
Its ok...I have reinstalled my OS
25-07-2006, 12:08 AM
#26 (permalink)
I too had faced this problem sometimes ago. Then I asked Microsoft for help. Then they called me and asked me to uninstal SP2 and again to install it in safe mode. My XP had not got any service pack in itself. It needs to be installed manulay after installation of XP
25-07-2006, 04:05 AM
#27 (permalink)
HELP AND SUPPORT
What do u mean when u say "My XP had not got any service pack in itself."
Search this Thread |
