Old 13-07-2006, 12:55 AM   #1 (permalink)
Default how to read a error message that flashes during shut down?
There is some error message flashing with a error sound during shutting down my computer working on xp pro.
I want to read it but as the comp shuts down faster i could n't read it . Is there a way to read such messages during shutting down?
Aanand is offline
Old 13-07-2006, 01:12 AM   #2 (permalink)
Learner
Kniwor's Avatar
Default Re: how to read a error message that flashes during shut down?
windows ket + R
then type "shutdown -a" and enter
this will stop shutdown.. read the message now
Kniwor is offline
Old 13-07-2006, 07:24 AM   #3 (permalink)
Press Win key+Pause, go to Advanced and select Error Reporting... If you have disabled error reporting, verify that "But notify me of critical errors..." is set to yes...
Arun
sakumar79 is offline
Old 13-07-2006, 11:10 AM   #4 (permalink)
Thanks for the reply. But unfortunately I don't have the <win key> in my laptop keyboard. Is there any other way to circumvent when the <win key> is not there? for instance i use <<ctrl+esc>> to access the "start" menu which normally can be done with the win key. once again thanks arun.
Aanand is offline
Old 13-07-2006, 11:43 AM   #5 (permalink)
Beware of the innocent
ilugd's Avatar
right click on my computer on the desktop and select properties. This is the equivalent of winkey +pause
ilugd is offline
Old 13-07-2006, 01:48 PM   #6 (permalink)
I downloaded the hotkey features from the IBM support site and now made my right <alt> key as win key.
It goes to system properties.
There the error reporting is enabled. ]
The error message occurs only when the Kerio personal firewall is running, it seems. If i turn off the kerio fire wall the message doesn't appear. Anyway I could nt find what is the errror message yet.
How to pause while the computer shuts down?
How to pause while the computer is shutting down?
Aanand is offline
Old 13-07-2006, 02:29 PM   #7 (permalink)
If you identify Kerio as the problem, try uninstalling it and using another firewall such as Outpost or ZoneAlarm...
Arun
