Old 12-07-2006, 06:44 PM   #1 (permalink)
Default Spyware Removal
My computer is effected by adware.look2me.How can i remove it.Please help.
vineetrocks2005 is offline
Old 12-07-2006, 07:23 PM   #2 (permalink)
Default Re: Spyware Removal
Check out http://www.pchell.com/support/look2me.shtml and http://www.symantec.com/avcenter/ven...e.look2me.html for removal tools as well as manual removal instructions...
Arun
sakumar79 is offline
Old 12-07-2006, 08:13 PM   #3 (permalink)
Distinguished Member
anandk's Avatar
Please download Look2Me-Destroyer.exe to your desktop.
http://www.atribune.org/ccount/click.php?id=7
Close all windows before continuing.
Double-click "Look2Me-Destroyer.exe" to run it.
Put a check next to "Run this program as a task".
You will receive a message saying Look2Me-Destroyer will close and re-open in approximately 10 seconds. Click OK
When Look2Me-Destroyer re-opens, click the "Scan for L2M" button, your desktop icons will disappear, this is normal.
Once it's done scanning, click the "Remove L2M" button.
You will receive a Done Scanning message, click OK.
When completed, you will receive this message: Done removing infected files! Look2Me-Destroyer will now shutdown your computer, click OK.
Your computer will then shutdown.
Turn your computer back on.
http://www.bullguard.com/forum/9/Adw...ool_24014.html
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 15-01-2009, 01:20 AM   #4 (permalink)
Malwarebytes removed that for me...
Fahey is offline
