Old 12-07-2006, 06:27 PM   #1 (permalink)
Default how to write .UDF files.
I have downloaded MS Vista beta. it is 3.125 GB. it shows .iso extension but when i try to write it using Nero, it cannot be written. there is a rar file saying that u need an OS which can wite UDF files. plz help.
I tried POWERISO also but no use.
Mangal Pandey is offline
Old 12-07-2006, 06:32 PM   #2 (permalink)
Google Bot
Pathik's Avatar
Default Re: how to write .UDF files.
try alcohol......
Pathik is offline
Old 12-07-2006, 08:05 PM   #3 (permalink)
royal's Avatar
Smile Re: how to write .UDF files.
You can also try CloneCD
royal is offline
Old 12-07-2006, 09:39 PM   #4 (permalink)
The Frozen Nova
casanova's Avatar
Almost any cloning s/w will do the job including Alcohol, CloneCD, BlindWrite, CD-RWin ....
Alcohol 120% and clonecd are better than others.
www.nerdweed.blogspot.com
casanova is offline
Old 13-07-2006, 02:43 PM   #5 (permalink)
The Researcher
you may try Roxio Easy Media Creator V 8
Ramakrishnan is offline
Old 15-07-2006, 09:14 AM   #6 (permalink)
thanx finally written it with clonecd. thanx for the guide. plz close this thread.
