26-11-2004, 01:37 PM
P2P Sharing
Can someone give me a good p2p file sharing software i have a broadband connection a home
Kazaa had too many ads would prefer if there where no ads
AMD Athlon X2 4200+
2GB DDR 400 RAM
nVIDIA 7800GTX 512MB x 2 SLI
Creative X-Fi Fatal1ty Sound Card
400+160+74GB HDD SPACE
26-11-2004, 01:44 PM
in linux use gnu_gunttela (spelling ?) its good no major overheads.
**** happens
26-11-2004, 01:45 PM
What about windows
AMD Athlon X2 4200+
2GB DDR 400 RAM
26-11-2004, 01:55 PM
Well there are lotsa available for windows man,just search a bit google.
Anyways I've been using Emule,Edonkey,Kazaa Lite & DC++.Search google for more info about them.
www.Oobertech.net
26-11-2004, 02:33 PM
Also you will want to try bittorrent. They give extremely good speeds.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
26-11-2004, 03:13 PM
Bittorrent is a good one.. I use ABCtorrent.. ABCtorrent is also good..
26-11-2004, 03:22 PM
Coming back to life ..
Shareza is good ... free and opensource ..
Bittorent is also nice ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
26-11-2004, 03:31 PM
For an all round client Shareaza is nice
Hardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
26-11-2004, 03:34 PM
BTW, If you had installed Kazaa make sure to run an Adaware SE & Spybot scan for spywares
26-11-2004, 06:22 PM
If u have good downloading speeds.......BIT TORRENT rocks
It\'s a truism that our worst affected wounds are self inflicted
Just Another F*$%/ed up day in Paradise
26-11-2004, 07:37 PM
Shareaza
and
Bittorent
... try nothing else .. no need
-Metallica
26-11-2004, 07:54 PM
Well if u want a Latest P2P Trend setter then Its definetly Bit Torrent....and if the Good Old All rounder then it Definetly has to Be Kazaa Lite 2.4.3 .....but be sure to load all ur antivirus updated just to be safe and yeah if possible even try to install a firewall(some of these P2P's wont work with the firewall though).....and the rest reamins tons of P2P choices Just google for it......
26-11-2004, 07:56 PM
well try warez P2P
available at www.warez.com
Incompatible message format
26-11-2004, 08:55 PM
Hey guys, I tried Bit Torrent on a 512 Kbps connection, and ur so called "Extremely good transfer rates" translates into 2 KBps - 5 KBps...
I suggest u use
Imesh 4 or Imesh 5 (beta) ( http://www.imesh.com ) (or)
Morpheus ( http://www.morpheus.com )
..::The Slam Team::..
26-11-2004, 08:57 PM
If you want small files, then eMule is the best. Its fast, free, open source, no spyware and you almost always get anything you want. Only problem is while downloading large files (>600 MB) you often end up with a p0rn movie instead
For large and popular files I recommend using IRC. Search the forums, I once posted a link on how to use IRC for downloading files.
_________________
Firefox
Rediscover the web
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
26-11-2004, 09:10 PM
Bewitched!
Shareaza!! it hangs in my systems
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
26-11-2004, 09:49 PM
Bewitched!
Can anyone give me the download link to Bitorrent....
27-11-2004, 08:45 AM
You probably have a crappy connection i.e. one that is not setup properly, it is a well established fact that BitTorrent is king when it comes to large files and fast downloads.
27-11-2004, 12:35 PM
#20 (permalink)
Well my old time favourite is still Winmx however currently i have started using Limewire : this later one is also quite good and has no hidden adwares or other instalations on your PC.
Also, i think you need to have a good updated Anti-virus, Firewall and adware scanners before you start using any P2P softwares.......
About kaazaa: i dont know why so many people still like it quite good, its has got quite a few irritating links with it and when i removed kaazaa these don't get deleted.  any thoughts about this from anyone??
Quote by Garfield'
27-11-2004, 01:29 PM
#21 (permalink)
rohan, Kaazaa is dead, gone, end of story. Bundling spyware was its own undoing.. I dont think anyone's using Kaazaa right now and if they are then they deserve to be kicked in their *** for using a software that supports spyware
Anyways, yeah its good that LimeWire doesn't bundle spyware anymore... Limeshop was the next deadliest spyware after CWS ..
_________________
Firefox
Rediscover the web
27-11-2004, 01:31 PM
#22 (permalink)
Kazaa Media Desktop 3.0
KaZaA Media Desktop offers you a total media experience. It is a second generation peer-to-peer file sharing service with which you can search and download media files from other KaZaA users.
You can also organise and play/view your media files through an integrated media jukebox, publish your own work, reach an audience and communicate with other users. It supports audio, video, software/games, images, and documents.
This software has no spyware installed. So I think youcan give it a try. coz its the new release
More & Download @ Click Here
Vande Mataram - Two words that became a Fiery War Cry and Electrified the nation towards Freedom. A mantra that instills a sense of Pride and belonging.
27-11-2004, 01:53 PM
#23 (permalink)
Vinay are you out of your mind? I dont think its worth a try!
KMD has been rated 1 / 5 (A person had actually rated it 2 for 5 because it improved his business- his business was in removing spyware  )
It still has loads of Spyware and who in their right mind would actually BUY a p2p program!!
Read more here:
http://fileforum.betanews.com/detail/971761196/1
_________________
Firefox
Rediscover the web
27-11-2004, 03:42 PM
#24 (permalink)
Well abt this ( new One ) :
Qnext - Universal P2P IM program
Here is a all in one Universal Messenger program for both Windows and Linux.
The name is Qnext and from the first point of view we can tell you that this is another great looking application. Qnext Universal Messenger lets you communicate not only with Qnext users, but also with MSN Messenger, ICQ, Yahoo & AIM users.
Supports P2P & IM !
More Info : http://www.go4i.net/modules.php?name...rticle&sid=138
Dexy check tht and reply me
27-11-2004, 06:43 PM
#25 (permalink)
Originally Posted by [deXter
]rohan, Kaazaa is dead, gone, end of story. Bundling spyware was its own undoing.. I dont think anyone's using Kaazaa right now and if they are then they deserve to be kicked in their *** for using a software that supports spyware
very true ...
y use kazaa when there are so many p2ps without any spywares
but u know .. thats not very true in case of K-Lite
i use k-lite .. and i see a lot of users connected peacefully .. im expecting that most of them are using k-lite like me
anyways .. when u r inside a firewal ..then u dont have many options for p2p
-Metallica
27-11-2004, 06:48 PM
#26 (permalink)
@vinay:
You can't use file sharing or video chat with someone who doesn't use Qnext. You can't send files to friends using AIM or YAHOO or MSN. This is a major draw back.
_________________
Firefox
Rediscover the web
27-11-2004, 08:44 PM
#27 (permalink)
every programs have some drawbacks ! there s nuthing efficient in this world ?
wat abt
* Lime Wire ?
* eDonkey ?
* DC++ ?
27-11-2004, 10:33 PM
#28 (permalink)
* LimeWire:
Very notorious for Limeshop; now removed though.
* eDonkey:
Searchs not that fast, sometimes there are no sources at all or file doesnt' start downloading immediately, most often p0rn movies downloaded when you least expect it (  )... Better to use eMule instead of ed2k
* DC++:
Server limitations. Some servers say you got too many files to share and dont allow you; while some servers say you got too little files so they dont allow you
_________________
Firefox
Rediscover the web
27-11-2004, 10:51 PM
#29 (permalink)
]* DC++:
which server asked u too many files ... u r a bit wrong
problems with dc are :-
-> min sharing limit is of the order of 100GB, most of us dont have such shares .. and of course there are bots which will kick u automatically if u share crap like windows/program files folders
-> there are just too many hubs .. ppl come to one hub and some time later shift to other hubs .. some hubs also have maxhubs=1 rule ..
so the end result is that one file which u found in search may not be available after 2 days cos the user joined some other hub today
other than that .. speeds are good and u get specific content like tv serials etc
im interested in downloading x-files, smallville, apprentice, that 70s show, yes minister, wonder years and of course lots of japanese animes ..
these are available in good quantity in dc
-Metallica
30-11-2004, 12:17 PM
#30 (permalink)
answer CLEANLY now...........
Which Is the best P2P File Sharing Program ??
Search this Thread |
