Old 09-07-2006, 08:34 PM   #1 (permalink)
shyamno's Avatar
Red face what is ?
Can any one tell me what is this process related to "wuauclt.exe".In the task manager it is there any consumes a much memory.
Made the title more descriptive
-tuxfan
shyamno is offline
Old 09-07-2006, 09:19 PM   #2 (permalink)
plsoft's Avatar
Default Re: what is ?
wuauclt.exe - This is used by the automatic update tool in Windows ME to check the Windows Update site every so often to see if any updates need to be installed.
In other cases, wuauclt.exe is a virus, spyware, trojan or worm! So i suggest u scan yur system properly with all the anti-virus,spyware, etc. u have.
plsoft is offline
Old 09-07-2006, 09:57 PM   #3 (permalink)
shyamno's Avatar
I am using Win XP SP2.Does it have any relation with this OS.
shyamno is offline
Old 09-07-2006, 10:05 PM   #4 (permalink)
dIgItaL_BrAt's Avatar
It manages automatic updates on XP too,so nothing to worry about.
dIgItaL_BrAt is offline
Old 09-07-2006, 10:48 PM   #5 (permalink)
nach p's Avatar
u can use "Process Explorer NT" to get detailed info abt every task running.
link to download this soft is as follows
http://www.sysinternals.com/Utilitie...sExplorer.html
No need to install and nearly 3mb sace required.
"UNIX is basically a simple operating system, but you have to be a genius to understand the simplicity."
-Dennis Ritchie
nach p is offline
