Old 09-07-2006, 02:01 PM   #1 (permalink)
Default HTML query
hi friends
i am working on a timetable manamengent system..in which i have to display the timetables of different teachers depending on data fetched from database..the problem is that how do i display the output in a typical timetable format...because the names of the subjects can be different and i want it to be general...i hope you understood the problem.. waiting for a reply..
thanks
Satyen
satyen_abrol is offline
Old 09-07-2006, 03:50 PM   #2 (permalink)
tuxfan's Avatar
Default Re: HTML query
You can't use plain HTML to fetch data from database! You will need something like PHP to do it for you. What database is that? Is it on a web-server somewhere? What's the setup for this application? Is it on an intranet or internet?
And please don't start multiple threads for the same problem!!
tuxfan is offline
Old 09-07-2006, 03:53 PM   #3 (permalink)
martian's Avatar
We cannot connect to a Database using plain HTML... You should try doing the same with AJAX, PHP, etc.
Oh my! Such a nice Planet...
But... what am I doing here??
martian is offline
Old 09-07-2006, 04:15 PM   #4 (permalink)
I dont think fetching from database is the problem but displaying it in the typical way is the problem.
Paschim is offline
Old 09-07-2006, 04:41 PM   #5 (permalink)
Once you put the name of the subject also in the database, you can retrieve it and display it as a variable through PHP+SQL
Arun
sakumar79 is offline
Old 09-07-2006, 06:53 PM   #6 (permalink)
Freinds fetching data from the data is not the problem.the problem is how do i present the data in the form of a timetable...what do i use in html to display the data...
And i have used JSP to connect to the the database MySQL..i again repeat fetching data is not the problem but how do i display it in the timetable format...
Last edited by satyen_abrol; 09-07-2006 at 07:20 PM. Reason: Automerged Doublepost
Old 09-07-2006, 09:54 PM   #7 (permalink)
Your table is basically HTML code consisting of recurring tabs (TR, TD, etc)... Just create a double loop for the table (one for the timeslot and one for the class to teach), put table level tags before the loop, row level tags in the first loop and cell level tags in the second loop... You will have to have PHP put out the whole Table code in generated HTML...
Arun
Old 10-07-2006, 11:05 AM   #8 (permalink)
tuxfan's Avatar
You need to use a loop (for, while, etc.) to display the table thats repetitive! I have a php Calendar that I made for a site. It had pecualiar requirements and so any existing one was not suitable. I wrote it from scratch.
If you need the code, PM me.
Frankly, your query is not too clear! What exactly is the problem? Are you not aware of table, th, tr, td, etc. code of HTML? Are you a HTML newbie? Whats the actual problem?
tuxfan is offline
