Old 09-07-2006, 01:07 PM   #1 (permalink)
tweety_bird_bunny's Avatar
Default slow speed over cross cable...??? :-(
i connected my laptop n pc with cross over cable and xp pro sp1 on both pcs....the connection was successful,, and i can share files....but the speed was very very slow....like for 2mb file it took 1-1.5 minutes to copy......
is this the max speed that i can get over such a connection....
plz tell me if there can b any tweak or suggestion for improvement...
tweety_bird_bunny is offline
Old 11-07-2006, 11:36 AM   #2 (permalink)
Default Re: slow speed over cross cable...??? :-(
Go to Control Panel -> System -> Hardware tab -> Device Manager. Select your LAN card and right click, then click on properties. Go to Advanced tab. Select the "Link Speed/Duplex Mode" Property and change its value from auto mode to "10Mbps Full Duplex mode". Click ok, exit and restart machine.
krish
Compaq Presario Notebook, AMD Mobile Sempron 3000+ (1.8 GHz), ATI Mobility Radeon Xpress (PCIe) 200M 128MB Graphics, 768 MB DDR 333 MHz RAM, 40 GB HDD, DVD+CDRW Combo, 15".....
krish is offline
Old 12-07-2006, 04:52 PM   #3 (permalink)
Thumbs up Re: slow speed over cross cable...??? :-(
thanx a lot krish ...u saved the day....
Old 12-07-2006, 05:09 PM   #4 (permalink)
You are welcome! I'm not asking for much but if u wanna thank me then just click on the thanks button below my previous post. I would love to see the thanks tag to my suggestion
krish is offline
Old 12-07-2006, 05:11 PM   #5 (permalink)
Beware of the innocent
ilugd's Avatar
thanks krish, I am going to try that. I once copied around 4 gb of files from one sys to another with ftp on the same lan. took me 14 hours. I should have used this.
ilugd is offline
Old 12-07-2006, 08:34 PM   #6 (permalink)
GaurishSharma.com
gary4gar's Avatar
what if we change is to 100Mbps Full Duplex mode??
gary4gar is offline
Old 30-11-2008, 01:27 AM   #7 (permalink)
Corrugator ...
Unhappy Re: slow speed over cross cable...??? :-(
Hi.. it didnt work yaar.. i get a max of 8MB/sec with 100Mbps full duplex mode !!
Please rescue asap ...
help me.. i made it 100Mbps on both the machines...
i have one XP machine and other Vista ..
i get a max of 8MB/sec ... pls rescue
junkymailer is offline
Old 30-11-2008, 01:43 AM   #8 (permalink)
Well, you have to change it to 10MBps and not 100MBps.. give it a try.. With 100MBps the speed drops a lot.
krish is offline
Old 30-11-2008, 10:48 PM   #9 (permalink)
UbuntuUser
cynosure's Avatar
Try using IP messenger. A great tool which will speed up the transfer rate. Worth a try, only ~100KB
cynosure is offline
