Old 08-07-2006, 10:54 PM   #1 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Exclamation Command prompt disabled?
i go to start--->run---->and type cmd...the command prompt opens and then i get a msg that Command prompt disabled by the administrator...It then closes suddenly and i myself is the administrator ...I also get a msg when i type regedit in the run dialog box that registry editing is disabled by the administrator
rakeshishere is offline
Old 09-07-2006, 12:18 AM   #2 (permalink)
JGuru's Avatar
Default Re: Command prompt disabled?
Looks like someone knowing the Adminstrator password has played spoil-sport.
That person knew these Registry tweaks very well - disabled Command prompt,
also knowing well that you'll edit the Registry to set things right , has disabled
regedit also!! You should never give your Adminstrator password to anyone.
Also don't use English words as passwords, rather use alpha-numeric codes.
JGuru is offline
Old 09-07-2006, 12:39 AM   #3 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
Start -> Run -> gpedit.msc.
Goto: User Configuration -> Administrative Templates -> System.
In right-side pane, Set the values of:
Prevent access to the command prompt &
Prevent access to registry editing tools
to either Not Configured or Disabled.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 09-07-2006, 01:58 AM   #4 (permalink)
HELP AND SUPPORT
@Vishal
Thanx a lot...the problem is solved completely
