07-07-2006, 06:43 PM
Cool as a CUCUMBAR ! ! !
Hide Ip ! ! !
any software 2 hide my Ip address ???
as i came 2 a site which gave my IP address along with all the details ...
am scared ...
07-07-2006, 07:29 PM
Wandering in the zone ...
Re: Hide Ip ! ! !
am scared ...
You can try HideIP to hide ur IP address.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
07-07-2006, 08:01 PM
HELP AND SUPPORT
Re: Hide Ip ! ! !
It doesnt work--Both Hide IP and HIde IP Platinum sucks as i tried while i was dwnldng something from rapidshare.Rapidsahre denied me and said me to wait for another freaking long time..People say it tracks ur ip adress and stuff so i used this s/w and it showed no results....
SurfAnonymous 1.1
IP Anonymizer 3.1
Hide My IP 1.0.2
These are gud ones and give a try for all of them
Reason: Automerged Doublepost
08-07-2006, 02:05 AM
Re: Hide Ip ! ! !
Byepass the Rapidshare data download limit
Rapidshare limits each user to a certain amount of downloading per day based on the users IP address. You can easily cheat rapidshare by showing a different IP address.
1. Clear your browser cookies.
2. Open the command prompt (Start - Run - cmd.exe)
3. Run the following simple commands:
ipconfig /flushdns
ipconfig /release
ipconfig /renew
4. Type exit to close the DOS window. Restart the rapidshare download job.
To follow the path:
look to the master,
follow the master,
walk with the master,
see through the master,
become the master. -Zen
08-07-2006, 06:45 AM
The pWnster
Re: Hide Ip ! ! !
hide ip platinum works gr8 4 me
Sigs suck
08-07-2006, 10:05 AM
-The BlacKCoaT Operative-
Re: Hide Ip ! ! !
you need something called NAT...
http://en.wikipedia.org/wiki/Network...ss_translation
NAT hides ur internal IP and uses a diff IP to communicate with the outer world. and i think it can be programmed to change the outbount mapping(changing IPs) at set intervals
08-07-2006, 03:46 PM
Re: Hide Ip ! ! !
The best way will be by using proxies.... dependin on the type of the proxy, u can change ur details about ur location/isp provider.. Hide ip platinum and others which u have mentioned use the same method...they search for a best proxy ip available, automatically configure ff/ie to go throught that ip without the direct one..
Still depending on the type of the ip, u can be traced/not
if u are using transparent ips, ur main ip(given by ur isp) can be traced, cause the callling headder contains both the proxy ip and main ip when u are using a transparent ip..
If u use a anonymous type ip, the headder details will be anonymous , but the main ip can also be found..
IF u use an highly elite anonymous type ip , the headder will never contain ur main ip....thus is highly difficult to get the main ip..
if u use an elite ip, u can bypass rapidshare as many rapidshare limit overcomin softwares uses the same road... they check weather the ip is good enough to overcome rapidshare....
But even elite ips arent completly anonymous ips....it can be traced...
The better way to this is using a proxy chain.... with loads of workin elite proxies.. this will minimise ur info displayed... but depending on the speed of each ip, ur browsing speed may be greatly reduced/slighty increased..
08-07-2006, 05:06 PM
The Thread Killer >:)
Re: Hide Ip ! ! !
Originally Posted by anarchist
thats all what sites can know; your ip address and your isp providor details
beyond that only your isp can go. no one will reach your home unless you are involved in a cyber crime and police is investigating the case.
...dont be scared.
thats all details which sites can know without police investigation.
Sorry, I beg to differ. There are loads of hacking sites which tell you your IP address, the ISP provider, the country(obviously, if they have found the ISP provider), your OS, your browser name and version and LOTS MORE. So, there is a necessity for you to be paranoid about your security. Do take care and use the softwares recommended by the users here.
19-04-2007, 01:22 PM
Rebooting
Re: Hide Ip ! ! !
Which Connection you are in ?? as right now no ISP in India is giving Static IP as necessarily that is Optional !!
Therefore dont select any such plan and stay on Dymanic IP... just DC and reconnect to change ur IP address !!
rebooting
ChotoCheeta.com
19-04-2007, 02:16 PM
wid million core procesor
Re: Hide Ip ! ! !
if u wanna surf anonymously it anonymouse.org , it simple and u dont need to install anything.Only -ve pt is that its a bit slow
Intel C2D E4300|4GB DDR2 800 RAM|1.5 TB HDD|Nvidia GeForce 9500GT 512MB DDR3|
19-04-2007, 02:31 PM
gooby pls
Re: Hide Ip ! ! !
All Hide IP softwares are cr@p except Anonymizer Anonymous Web Surfing (7-day-trial ),it is the only which works in all browsers.
19-04-2007, 02:42 PM
Rebooting
Re: Hide Ip ! ! !
as for proxy, long time Back in 2004 a Geek in Network (Digen he was i think) here at Digit Forum recomeded me TOR if you know how to confiure it (not very difficult though  ) is the Best in Bisuness, more over its free
Read more about TOR, http://tor.eff.org/
rebooting
ChotoCheeta.com
20-04-2007, 11:27 AM
Re: Hide Ip ! ! !
yes u r right ........ installed hide ip platinum .........
it DOESNT work 4 me ......... rapidshare still detects my IP ........ thry r really smart ppl outthere ...........
20-04-2007, 11:38 AM
Host4Cheap.org
Re: Hide Ip ! ! !
Rapidshare doesnt detect your IP. The reason is....Hide IP has a few number of proxies in its database and lots and lots of people us e Hide IP. Since the no of proxies is limited, the IP you get from Hide IP has already been used by someone else to download from RS
http://www.host4cheap.org/
20-04-2007, 11:27 PM
Re: Hide Ip ! ! !
there is no need of hiding ip... although u try to hide in some way it is being explored
Do or Die
http://www.hamrobrt.com/howto-install-flash-player-in-ipad/
Search this Thread |
