Old 25-11-2004, 03:03 PM   #1 (permalink)
mariner_5147's Avatar
Default Warcraft III problem.....Please Help
I tried to run Warcraft at a certain screen resolution which my monitor doesn't support (reverting didn't happen, may be because I accidentaly pressed the enter button and the resolution got fixed). The screen went blank, with the usual blinking of the monitor LED. After that I am unable to run the game. I tried reinstallation and completely erased the game folder, but the screen resolution remain fixed ie blank. I am running XP home edition.
I want to know where Warcraft stores the resolution info on the computer, any particular file or in the registry?
Thanks for any help
its either 0 or 1
mariner_5147 is offline
Old 26-11-2004, 12:09 PM   #2 (permalink)
Default Use the registry !
Use the search available in registry editor, and find warcraft, or the distributors name. May b u will find the resolution key in there....Try ur luck..
Or else totally uninstall warcraft III ..install jv16 powertools from http://www.jv16.org (or) http://www.macecraft.com/downloads/jv16pt_setup.exe
Use the Registry cleaner in that...find the entries related to warcraft in that..delete them all...B careful not to remove any others...
Now reinstall warcraft in a directory other than the previous one !!!
Njoy !!!
..::The Slam Team::..
Slam Team is offline
Old 26-11-2004, 03:47 PM   #3 (permalink)
Thnx...will give that a try...
its either 0 or 1
Old 26-11-2004, 04:08 PM   #4 (permalink)
Dont need to do all that. The problem as you have rightfully identified it is a monitor issue. Just use Refresh Rate Overrides at 60Hz in the monitor and it will work fine.
AMD 64 3500+ Venice
DFI Lan Party Ultra-D
XFX 7900GT 256 MB Card
icecoolz is offline
Old 27-11-2004, 09:47 AM   #5 (permalink)
thnx ice...its now working fine
its either 0 or 1
