Old 05-07-2006, 09:28 PM   #1 (permalink)
Smile what to do
what precautions b taken while using net and p2p in XP?
devdatta is offline
Old 05-07-2006, 09:33 PM   #2 (permalink)
dIgItaL_BrAt's Avatar
Default Re: what to do
Use a good AV,Firewall and Anti-Spyware app.
That's it.
dIgItaL_BrAt is offline
Old 05-07-2006, 10:16 PM   #3 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Nothing.
No Firewall, No AV, No AntiSpyware , No precautionary measure you need to take IMO.
Been using p2p since it has been around.. I have not been infested *even once*.
drgrudge is offline
Old 05-07-2006, 10:51 PM   #4 (permalink)
Originally Posted by drgrudge
Nothing.
but it's better to be safe than sorry!
Old 06-07-2006, 12:22 PM   #5 (permalink)
champ_rock
champ_rock's Avatar
i completely agree with @drgrudge...
u should knw what kind of a file u should download.. like a file which is very popular has very less chances of being infested with a virus... u should look at the size also. . for ex. some software which is about 10mb.. is shown as 50mb.. then there is something fishy about it.. dont download it..
Registered Linux user number 400618
champ_rock is offline
Old 06-07-2006, 01:12 PM   #6 (permalink)
dattebayo
anispace's Avatar
yeah p2p is safe...according to my experience. Been using it since the past 6-7months and never got infected. yeah i agree with champ_rock tht u should know which file to download and how large is it etc. other than that its safe.
I have only Avast home edition and Zonealarm home edition(since the past few days) installed.thats it.
anispace is offline
Old 06-07-2006, 02:05 PM   #7 (permalink)
More important that AV and spyware, a firewall is more critical to avoid intrusion from hackers...
Arun
sakumar79 is offline
Old 06-07-2006, 02:42 PM   #8 (permalink)
go_gamez's Avatar
to be on the sfer side..use zone alarm total security suite ..
any way it also depends on which p2p are u using ...never use kaaza..thats full of spyware..u can try bareshare..
any way which p2p do u all use ??
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
Old 06-07-2006, 06:02 PM   #9 (permalink)
Distinguished Member
anandk's Avatar
best to use zass or any such integrated security suite, when on the net.
> www.TheWindowsClub.com <
= www.WinVistaClub.com =
Microsoft® MVP
anandk is offline
Old 06-07-2006, 08:55 PM   #10 (permalink)
samrulez's Avatar
Use a firewall and a anti virus.....keep the definitions up-to-date.....While using P-2-P s/w avoid downloading *.exe files......
Sam :D Rulez :lol:
samrulez is offline
Old 07-07-2006, 06:09 AM   #11 (permalink)
nil_3's Avatar
P2Ps are generally safe(especially torrents and Gnutella networks). I am using for the last one year without any problem. However, at browsing, there are some sites(like some crack-sites) where you can get infected with spyware. So "Use a good AV,Firewall and Anti-Spyware app" as dIgItaL_BrAt advised.
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
