Do we have a software which can encrypt my Cpp files in a single .exe file & i can access it through dos shell netime & can retrieve back my program .... actually i have a program which does the same but tell me if there is ne such s/w which can help me in this???
At times in ur life just to do things right U have to be steady & sacrifice sth which u want the most.....even ur dreamzz tooo....
Hmm. . You can use archiver for this .. Just archive them with encryption ... WinRAR has a command line mode so it will help you with it ..
And I wait without you ...
With or without you ..
Batty = Too Busy Now !!!
In WinZip or WinRAR and select Self Extracting Archive option to create exe file which when run unzips the files to specified destination.To encrypt use the encryptions in WinZIP or WinRAR.
