Old 04-07-2006, 07:04 AM   #1 (permalink)
Default Which is more reliable-SHaPlus or DU Meter?
Hi!I am a new user to BSNL DATAONE.I am on the Statrup 250 Plan and so very paranoid of the bandwidth usage.Was using both ShaPlus Bandwidth Meter 1.0 and DU Meter 3.0(build id 200) to check usage.Problem is the usage is shown differently in each.In fact usage shown by DU Meter is far higher than ShaPlus.
Question is:which do i trust??
Please help!
a ship is safest at the harbour but thats not what its built for!
serendipiti is offline
Old 04-07-2006, 07:58 AM   #2 (permalink)
nil_3's Avatar
Default Re: Which is more reliable-SHaPlus or DU Meter?
Shaplus is better. It can calculate the averaged overlapped usage. For the latest version of it search at http://www.shaplus.com/dataone/
P4 3.0GHz Dual-core.
Intel 945GNT MoBo.
1GB RAM.
Seagate 160GB SATA HDD.
HP 16X Dual Layer DVD Writer.
Coloursit 450Watt SMPS with NAVTECH cabinet.
Samsung SyncMaster 740N TFT LCD 17" monitor.
nil_3 is offline
Old 04-07-2006, 06:03 PM   #3 (permalink)
The pWnster
Vyasram's Avatar
du meter calculates the bandwidth used by ur pc directly
shaplus downloads the data from bsnl's server , adds em up and gives u the result. i prefer the use of both
Sigs suck
Vyasram is offline
