Old 03-07-2006, 03:20 PM   #1 (permalink)
HELP AND SUPPORT
rakeshishere's Avatar
Post µTorrent 1.6 Final
Micro-Sized Yet Feature Filled
Most of the features present in other BitTorrent clients are present in µTorrent, including bandwidth prioritization, scheduling, RSS auto-downloading and Mainline DHT (compatible with BitComet). Additionally, µTorrent supports the Protocol Encryption joint specification (compatible with Azureus 2.4.0.0 and above, BitComet 0.63 and above) and peer exchange.
Resource-Friendly
µTorrent was written with efficiency in mind. Unlike many torrent clients, it does not hog valuable system resources - typically using less than 6MB of memory, allowing you to use the computer as if it weren't there at all. Additionally, the program itself is contained within a single executable less than 160 KB in size.
Skinnable and Localized
Various icon, toolbar graphic and status icon replacements are available, and creating your own is very simple. µTorrent also has support for localization, and with a language file present, will automatically switch to your system language. If your language isn't available, you can easily add your own, or edit other existing translations to improve them!
rakeshishere is offline
Old 05-07-2006, 11:25 AM   #2 (permalink)
 Macboy
goobimama's Avatar
Default Re: µTorrent 1.6 Final
What's new in the 1.6 as against the 1.5 version?
I'm like a bird... :)
goobimama is offline
Old 05-07-2006, 07:41 PM   #3 (permalink)
Wandering in the zone ...
manas's Avatar
Heres the full changelist.
- Feature: Ability to filter files in torrent creator
- Feature: Add a move to top/down button or key
- Feature: Add a way to make µt startup in bosskey mode
- Feature: Add a way to set the upload/download cap through system tray
- Feature: Add an option to reset bans
- Feature: Add remaining HD space in the BC-style dialog
- Feature: Added "Completed On" column
- Feature: Added a way to delete the internal peerlist
- Feature: Added bandwidth priority and tracker status column
- Feature: Added graphical progress bar in main list
- Feature: Added option to allow multiple connections from same IP.
- Feature: Added option to bypass the Nanotorrent search redirect.
- Feature: Added option to open download bar when doubleclicking a torrent
- Feature: Allow torrents in list to be renamed
- Feature: Change label from the torrent properties dialog
- Feature: Delete torrents to trash
- Feature: Disk statistics
- Feature: Draggable download bars separate from the main window
- Feature: Enable scheduler from tray
- Feature: Make shift + delete key remove torrent + data
- Feature: New disk cache settings
- Feature: Open containing folder selects the item
- Feature: Open the folder if you click on the tray popup when a download is finished
- Feature: Pause in tetris
- Feature: Proxy for peer connections
- Feature: RSS update interval
- Feature: Remember waste/hashfails across sessions
- Feature: Removing torrent will remove partfile
- Feature: Set default action for delete button (right click on it and hold shift)
- Feature: Setup outgoing port to bind to
- Feature: Show a warning if no disk space when moving a complete torrent
- Feature: Show a warning in the add dialog if the torrent doesn't fit on the drive
- Feature: Show speed in title bar
- Feature: Show speed limits in status bar
- Feature: Shutdown/hibernate when downloads complete
- Feature: Standby when torrents complete
- Feature: Torrent create dialog remembers the previous settings
- Change: 'min interval' was misspelled.
- Change: Added buttons to select all / deselect in the add dialog
- Change: Added option not to connect to port 25 or 110
- Change: Auto Shutdown Windows available from a menu
- Change: Change so it always shows 3 digits in sizes.
- Change: Changed connections for the 384k speed
- Change: Delay firewall opening a little to help problem where utorrent starts faster than the firewall.
- Change: Don't delete torrents from list if the torrentfile wasn't found
- Change: Don't resolve peer ips by default
- Change: Don't switch between green/yellow icon too often
- Change: Don't use router.bittorrent.com
- Change: Edit button in RSS feeds window
- Change: Fixed various language strings to be more consistent
- Change: If the file cannot be opened, delay a little while and try again.
- Change: Increased length of editbox for new labels
- Change: Modified algorihtm for giving extra upload slots
- Change: More dialogs are non-modal
- Change: Never request more than 50 chunks from a bitcomet peer
- Change: New UPnP code (works on all OSes)
- Change: Redesigned settings dialog (I still need icons for the categories)
- Change: Remember the last speed tab view mode
- Change: Resolve IPs is on by default, but only if the Peers tab is active.
- Change: Separate the tracker from the webui + webui settings
- Change: Show a message in the logger if the autoload is set to the same as the storage folder.
- Change: Show a warning dialog when auto shutting down
- Change: Show better error message when adding a torrent through URL and it can't be loaded
- Change: Show decimal in download bar
- Change: Speed in title bar is shown a little differently
- Change: Swapped UL/DL in download bar
- Change: Trim spaces from tracker url in create torrent dialog
- Change: Tweaked piece selection algorithm a little
- Change: num_wsa_events to control how many WSA EVENTS to allocate
- Change: peer.lazy_bitfield enabled by default.
- Change: Changed the network status icons
- change: Moved the network status icon a bit
- Fix: Couldn't use Unicode characters with search box
- Fix: Don't allow blank filenames for single-file torrents (uses default name instead)
- Fix: Don't crash if popup menu is active while the active torrent is deselected
- Fix: Fixed Win95 problems.
- Fix: Fixed a bunch of crash bugs.
- Fix: Generals tab should flicker less
- Fix: Make the after crash re-check not re-check torrents that already finished in that session
- Fix: Never create torrents with more than 64k pieces.
- Fix: RSS Favorites list bug
- Fix: Resize some labels to make more space
- Fix: Setting upload/download limit uses the currently active limit
- Fix: Superseeding should work better
- Fix: The label entry box in the BC-style dialog is too short
- Fix: Wrap comments field
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 05-07-2006, 09:02 PM   #4 (permalink)
thunderbird.117
Posts: n/a
Azureus is 100% better than Utorrent
Old 05-07-2006, 09:59 PM   #5 (permalink)
manas's Avatar
Azureus is good,but it taxes the system resources very much.
manas is offline
Old 05-07-2006, 10:35 PM   #6 (permalink)
thunderbird.117
Posts: n/a
Yes becos of JAVA.
Old 05-07-2006, 10:36 PM   #7 (permalink)
HELP AND SUPPORT
Ok now...Stop talking about ur clients coz there is another thread for torrents clients which is very sticky
Old 06-07-2006, 03:40 PM   #8 (permalink)
saurabh.sauron's Avatar
i like utorrent coz u dont have to install it, doesnt tax ur resources and gives decent speeds.
i think there is an installable version available.
saurabh.sauron is offline
Old 07-07-2006, 08:01 PM   #9 (permalink)
siriusb's Avatar
I like utorrent and use it and all, but I long to return to azureus simply because azureus is pluggable (pluggable-innable?). I simply hate the scheduler in utorrent. The Speed Scheduler plugin in azureus was awesome and can be set perfectly for my double-bandwidth times and permits capping upload speed. Hoping for this to change in one of the versions.
http://myxp.blogspot.com
Winchester 3200+ @2,500MHz
siriusb is offline
Old 08-07-2006, 07:25 AM   #10 (permalink)
AMD user for 9 yrs!!
rollcage's Avatar
Absolutely right ... Azureus with Plugin Speed Scheduler 1.3 ... works gr8 for people who have night plans
rollcage is offline
Old 08-07-2006, 11:01 AM   #11 (permalink)
Another Brick in the Wall
drgrudge's Avatar
Yes, this upload capping is a big issue. It's not suitable for capped connections like Dataone.
Been using this for some 3-4 days.. the speeds are not constant (it's varying and sporadic) and we can't allocate a particular BW for a torrent also. If can cap the upload speed (and our download speeds are not limited) then this is perfect.
drgrudge is offline
