Old 02-07-2006, 11:26 AM   #1 (permalink)
Wandering in the zone ...
manas's Avatar
Question Best MP4/AAC converter
I want to know whether MP4 and AAC are the same and which is the best software to convert mp3 files to mp4 or AAC.
Not all those who wander are lost. :D
http://www.manast.com ---- ManasT
manas is offline
Old 02-07-2006, 07:13 PM   #2 (permalink)
shovik's Avatar
Default Re: Best MP4/AAC converter
No MPEG-4 and AAC are not the same.
See the following links ::
[for mp4]http://en.wikipedia.org/wiki/MP4
[for AAC]http://en.wikipedia.org/wiki/Advanced_Audio_Coding
For your second query,
the best mp3 to mp4 converter is the dbpowerAMP, download it from ::
http://www.dbpoweramp.com/dmc.htm
Regards,
Shovik.
shovik is offline
Old 02-07-2006, 08:24 PM   #3 (permalink)
bizzare_blue's Avatar
I think Quick Time Pro is a better converter for converting mp3's into mp4 or AAC.....Nero's converter(Nero Media Player) is also a good option for converting files...
Bitten by the open-source bug...
bizzare_blue is offline
Old 02-07-2006, 08:58 PM   #4 (permalink)
JGuru's Avatar
Yeah, QuickTime Professional is the best one. But you have to buy it to use it!!
AAC gives the best sound quality. Apple uses it in Mac OS. Beware most DVD
players in India can't play AAC file format!!! You can also encode the MP3 files
at a higher bit rate (that increases the file size & also gives better audio quality.
JGuru is offline
Old 02-07-2006, 09:04 PM   #5 (permalink)
shovik's Avatar
But QuickTime Pro is not a freeware and its a rather hefty download, whereas dbpowerAMP is a mere 2.1Mb download and it does all the job which any other highend converter can do.
Regards,
Shovik.
shovik is offline
Old 02-07-2006, 10:29 PM   #6 (permalink)
manas's Avatar
Thanks,will use dbPoweramp
manas is offline
Old 02-07-2006, 10:51 PM   #7 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
I use iTunes to convert MP3 into AAC, & it works too good.
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 03-07-2006, 08:47 AM   #8 (permalink)
manas's Avatar
^^Vishal,how much CPU and RAM does iTunes take when minimized ?
manas is offline
Old 03-07-2006, 09:26 AM   #9 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Red face Re: Best MP4/AAC converter
im also stuck wid da mp4 prob but wid me it is a id file ......
8 Mile - Eminem - Full Movie - DivX.mp4...........
i hv tried over 10 players and codec packs but this file refyses to play i redownloaded but again da same prob.....file plays well on my friends lappy...
Ambar is offline
Old 03-07-2006, 09:32 AM   #10 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
^^ Try VLC player from http://www.videolan.org
kalpik is online now
Old 03-07-2006, 03:31 PM   #11 (permalink)
aka. ViKiD? <^_^>
Ambar's Avatar
Cool Re: Best MP4/AAC converter
tried dat also but it also doesent help.....
Ambar is offline
Old 03-07-2006, 06:46 PM   #12 (permalink)
Microsoft MVP
@manas
It takes 5 MB RAM approx. in Minimized mode.
Old 06-07-2006, 12:58 AM   #13 (permalink)
Main use of AAC/MP4 Audio are
1) Quality audio at lower bitrates (Similiar to 320kbps MP3 Format)
2) Improved audio quality at higher bitrates (Better than 320kbps MP3 Format)
For encoding the best option is nero 6 or 7 ultra edition
If you are planning to hear MP4 in mobile phones nero is'nt a good option,go for Imtoo 3gp converter (http://www.imtoo.com/3gp-video-converter.html)
Prince Stephen Ranji is offline
Old 06-07-2006, 07:55 PM   #14 (permalink)
t3h g04t
teknoPhobia's Avatar
If you have a Nokia phone which supports music playback, the Transfer music app in PC Suite 6.8 is really good.
technologically challenged.
teknoPhobia is offline
- by gohan89
