Old 23-11-2004, 11:08 PM   #1 (permalink)
Default [ WhoLockMe ] Find out which process is locking your file!
What is WhoLockMe ?
Have you ever bored by this Windows message : "Error Deleting File or Folder, ... There has been a sharing violation. The source or destination file may be in use.", when you try to delete, move or rename a file ?
WhoLockMe is a little extension for your Explorer. It permits you to list all the process locking your selected file.
Download this freeware (22 KB)
Source: Dr Hoiby
_________________
Firefox
Rediscover the web
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 23-11-2004, 11:34 PM   #2 (permalink)
swatkat's Avatar
I knew this one!
But is there any app which analyses the extensionless file and say which is the right app. for the file,i have HEARD that there is a website which does the samething online,but is there any software?
http://swatrant.blogspot.com/
swatkat is offline
Old 24-11-2004, 12:00 AM   #3 (permalink)
Well, funny you should say that! Because a program called as TrID, which does just that, was released just yesterday!
TrID is a utility designed to identify file types from their binary signatures. While there are similar utilities with hard coded rules, this has no such rules. Instead, it is extensible and can be trained to recognize new formats in a fast and automatic way. It uses an XML-based database of definitions which describe recurring patterns for supported file types. You can help creating new definitions. Just run the TrIDScan module against a number of files of a given type. The program will do the rest.
http://fileforum.betanews.com/detail/1059234726/1
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 25-11-2004, 06:31 AM   #4 (permalink)
The Photoshop Guy
cooljeba's Avatar
u can do that manually too.....
renaming the folder
lets create a new directory!
md hel (enter new direcotry created)
ren hel alt+255 (renaming the folder to the ascii value 255 )
folder locked!!
to unlock do the vice versa
i.e. ren alt+255 hel
well this works on 98 and me only....
..:: peace ::..
Jeba
cooljeba is offline
Old 25-11-2004, 06:38 AM   #5 (permalink)
alib_i's Avatar
that's awesome man ....
thnx dexy ...
i've been looking for something like this for a long time !!!
-Metallica
alib_i is offline
Old 25-11-2004, 10:51 AM   #6 (permalink)
Good info m8.
Simple things are to simple too understand.
Prashray is offline
Old 25-11-2004, 09:38 PM   #7 (permalink)
renaming the folder
folder locked!!
..:: peace ::..
Jeba
lol.. no dude, you got me wrong! Thats not what this program is for- locked as in not locked from prying eyes, but locked from access because some process is using the file. For instance say due to some spyware or something you try to delete a file from the desktop, but you get an error message saying that file is in use; access denied, etc. This program can tell you which process is exactly using/locking the file.
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 25-11-2004, 09:51 PM   #8 (permalink)
The Photoshop Guy
cooljeba's Avatar
oops :-S
thanks for the info dexy :-S
dat strarting message box confused me
..:: peace ::..
Jeba
cooljeba is offline
Old 25-11-2004, 10:58 PM   #9 (permalink)
Version 2.0
Deep's Avatar
oh great...
thanks for the info man...seems to be be very useful app
Deep
- Deep Ganatra -
www.whoisdeep.com
www.twitter.com/DeepXP/
Deep is offline
Old 26-11-2004, 11:39 AM   #10 (permalink)
Bewitched!
xenkatesh's Avatar
Gr8 info* keep it up dexy!!!!!!
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 08-12-2004, 03:53 PM   #11 (permalink)
Default File Extensions
There is a software named File Extension database,which contains file and domain extensions.
U can see the extension refers to what program??
http://Camtech2000.net
lovedeepchd_2004 is offline
Old 08-12-2004, 06:43 PM   #12 (permalink)
alib_i's Avatar
Default Re: File Extensions
y is it that im not able to make sense out of most your posts lovedeep
the program is to know which application is locking a file ..
not to find which application is registered to which extension
-Metallica
alib_i is offline
Old 08-12-2004, 07:17 PM   #13 (permalink)
vysakh's Avatar
thanks [deXter]
man u are a real real real real computer geeeeeeeeeeeeeeek
Incompatible message format
vysakh is offline
Old 08-12-2004, 09:08 PM   #14 (permalink)
Another Brick in the Wall
drgrudge's Avatar
well, i downloaded now!
and it is a good program. tnx for sharing dexy!
drgrudge is offline
- by gohan89
