Old 30-06-2006, 02:28 PM   #1 (permalink)
Default overclocking help
im tryin to overclock my cpu and i was wondering as to which program i can use to test the ability of my pc to remain stable...can ne1 help?
p4 2.0A
geforce 4 ti4200
intel d845gbv
512 mb ddr266
thanks!!
CyBorG3132 is offline
Old 30-06-2006, 03:02 PM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: overclocking help
Prime95
OCCT
Memtest
Sissandra(burnin modules)
To check stability of gfx card play games that u have played many times before so u can see if these are any error in rendering or anything
Rollercoaster is offline
Old 30-06-2006, 04:11 PM   #3 (permalink)
JGuru's Avatar
Not only memTest also over-heating tests. Definitely if you over-clock , the CPU
temperature is going to shootup. Over-Clock little-by-little, simultaneously check the
temperature. A good big copper heatsink will also help. Too much over-heating
results in a burnt motherboard, so be cautious!!
JGuru is offline
Old 30-06-2006, 08:02 PM   #4 (permalink)
Why only Mobo, what about the processor?
V.Prem Kumar
janitha is offline
Old 30-06-2006, 11:33 PM   #5 (permalink)
my processor's stock speed was 2.0 ghz. i ocd it to 2.15 ghz and got these readings in sisoft sandra in the burn in test after 10 runs:
Board Temperature : 46.0°C (Min 40.0°C; Avg 45.7°C; Max 49.0°C)
CPU Temperature : 59.0°C (Min 43.0°C; Avg 57.3°C; Max 61.0°C)
are these temperatures normal ?can i overclock further? plz help!
Old 01-07-2006, 11:53 AM   #6 (permalink)
JGuru's Avatar
That looks OK to me. I also want you to stress-test the machine under heavy-duty
Graphics game like Doom 3. After over-clocking also check with 3D Mark 2005
scores. See how much difference you notice between previous state ( normal state)
and after overclocking (hyper-state).
JGuru is offline
Old 07-07-2006, 02:38 PM   #7 (permalink)
Google Bot
Pathik's Avatar
hi jguru wats the max safe temperature of the proc/mb
Pathik is offline
Old 07-07-2006, 03:01 PM   #8 (permalink)
nik_for_you's Avatar
for overclocking you can also use bios. you can increade the clock speed frm ther.. total cpu speed = clock speed x multiplier .
if clock speed is 200mhz and multiplier is 10 then cpu speed is = 2 ghz
I AM REBEL
nik_for_you is offline
- by gohan89
