Old 30-06-2006, 12:08 PM   #1 (permalink)
readermaniax's Avatar
Default .;-{w*ndow$ Partition Help}-;.
Now,
I want to ask that
my c:/ is of 14.01 gbs
but now due to lack of space i want to remove at least 5 gbs from my c:/ which r free
so can i remove it from c:/ and add it to some other drives without formatting c:/ and reinstalling W*NDOW$????
Please Help me Ia A Newbie in this thing!
My Favourite Blogs -
http://Mysticgadgets.com | Gadget Weblog
http://Mantosuperman.blogspot.com | Styleing Tips, And Evrythign You Need
Selling RS and vPP..
readermaniax is offline
Old 30-06-2006, 12:18 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: .;-{w*ndow$ Partition Help}-;.
u can use partion managers on this regard. just google with partion managers as keywork
gary4gar is offline
Old 30-06-2006, 12:24 PM   #3 (permalink)
Can u PLa write a tutorial for me on ths?
Old 30-06-2006, 12:56 PM   #4 (permalink)
JGuru's Avatar
You can use Ranish Partition Manager software.Get it from here:
http://www.ranish.com/part/
Always backup your drive before resizing partitions!! Sometimes it may lead to data
loss also. Read the 'Readme.txt' file first (http://www.ranish.com/part/readme.txt)
before doing anything.
JGuru is offline
Old 30-06-2006, 02:25 PM   #5 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
U can use Partition Magic, it'll do the job perfectly!
Run the program and it'll show ur existing 3 partitions in the list.
1.) Right-click on C: Drive and select Resize/move option and decrease it size according to ur requirements!
2.) Now right-click on the other partition, to which u want to allocate the free area and select again Resize/move option and increase its size!
Finally click on Apply button!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-06-2006, 02:27 PM   #6 (permalink)
String Phreak
mediator's Avatar
Hey the image says u have free space of > 9GB on c: ....Why uwanna free up space??
Neways u can remove heavy duty softwares like visual studio 2003 if have that etc!!!
mediator is offline
- by gohan89
