I bought P4 1.8Ghz PC in oct-03.i am having LG 15" monitor.since then i am facing the problem.whenever i try to make the computer resolution 1024X768 the whole screen becomes black and the dialogue box appears specifying that " Voltage Out Of Range " and after 20 seconds monitor automatically shuts off.Please Suggest a solution for this
#Well first of all Install the correct Display drivers /DL newer if necessary
#this aslo happens if u select a refresh rate that the ur monitor cannot support so reduce the refresh rate slightly most monitors display 1024x768 @ abt 85hz so if u force ur monitor to 1024x768 @ 100hz then it will show Signal out of range, also if u select a resolution supported by the display card but which is not supported by ur monitor..u can see similar errors
Risk more than what others think is safe.
Care more than what others think is caring.
Think more than what others think is thoughtful.
Do more than what others think is possible.
Arrey yaar just change ur frequency to 60hz and then just apply that,after that change ur display mode from 800*600 to 1024*768,and buddy it will perfectly work,dont worry for that!!!!!!!!!!and do reply when u try it!!!!
