Old 27-06-2006, 08:46 PM   #1 (permalink)
Default How do you know if a CD has been burnt or not?
I want to know how you can find tshis out WITHOUT putting it in a CD Drive. Like my friend just looks at the Optical surface, and he knows wether it' been burnt or not. Is there a mark or something there?
http://www.geocities.com/fortesaber99/
I'm back from hell,
with loathsome thoughts to sell.
Secrets of death to tell,
and horrors from the dark abyss..
fortebuster is offline
Old 27-06-2006, 09:20 PM   #2 (permalink)
GaurishSharma.com
gary4gar's Avatar
Default Re: How do you know if a CD has been burnt or not?
there is some special diff between burned disc & blank.try comparing a blank cd & a fully cd burned by u.i hope u will get the diff
gary4gar is offline
Old 27-06-2006, 09:26 PM   #3 (permalink)
dIgItaL_BrAt's Avatar
the burnt area is usually a little darker than the area to which data has not been written.
dIgItaL_BrAt is offline
Old 27-06-2006, 09:33 PM   #4 (permalink)
TechGuru#1's Avatar
yeah that's the basic check!
TechGuru#1 is offline
Old 27-06-2006, 09:52 PM   #5 (permalink)
Oh, Ok I got it.
Thanks guys.
I'm back from hell,
Old 28-06-2006, 12:05 PM   #6 (permalink)
gaurav21r's Avatar
Yea... if you see your cd in some light..you'll be able to see a clear dark circle, concentric with the outer rim nd the hole inside, the dark disc is basically an indication of the amount of data burnt on the cd, but its diff to distinguish b/w a completely written cd and a blank one coz a full disc has the dark layer all the way till the outer rim. So, in that case, u just gotta distinguish b/w the colour...a blank cd is lighter..................
gaurav21r is offline
Old 28-06-2006, 12:09 PM   #7 (permalink)
Beware of the innocent
ilugd's Avatar
wow, I never though of that. good question fortebuster
ilugd is offline
Old 29-06-2006, 08:20 AM   #8 (permalink)
ramprasad's Avatar
guys, to tell th etruth, it is hard to differentiate btn a completely burnt CD and an empty CD.... by seeing the darkness of the surface
Atleast, I have found it difficult to do that.....
ramprasad is offline
Old 29-06-2006, 09:39 AM   #9 (permalink)
In Pursuit of "Happyness"
kalpik's Avatar
Its only easy to recognise half burnt CD's..
kalpik is online now
Old 29-06-2006, 12:30 PM   #10 (permalink)
JGuru's Avatar
It's not difficult , but with trained eyes , you can spot the difference between a burnt CD or an empty one.
JGuru is offline
Old 29-06-2006, 12:51 PM   #11 (permalink)
The Researcher
Wow I never even thought of it.
Ramakrishnan is offline
Old 29-06-2006, 04:52 PM   #12 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
dude... been there done that!!
i can tell the diff so easily as if it was printed in BIG BOLD letters...
Rollercoaster is offline
Old 29-06-2006, 06:51 PM   #13 (permalink)
champ_rock
champ_rock's Avatar
hey one more thing, i was shopping at pallika bazar (pirated market in delhi)
actually i had to exchange some cds which were not working, that guy looked at the disk surface and told me that the disk had been used.. he could tell by looking at the surface that it has been used??? hows that possible, i mean some other shade difference comes if u use ur disk or what/.?
Registered Linux user number 400618
champ_rock is offline
Old 29-06-2006, 08:11 PM   #14 (permalink)
Microsoft MVP
Vishal Gupta's Avatar
He might looked at the scratches on CD Surface!
:arrow: http://www.AskVG.com/
Vishal Gupta is offline
Old 30-06-2006, 12:08 AM   #15 (permalink)
go_gamez's Avatar
its very simple.....a brand new blank disc..has a dark circle which is like on the most minimum possible circumference (in the inner side ) u can think of...and as soon as it is written ..the dark circle moves out of the area..like u can see two rims /dark circles togther in a totaly blank disc...while even if the disc is slightly written(like 1-2mb) also ..the two circles get separated ..havent u guys noticed..it i have been doin this for almost 2 yrs now ..its so easy...and it is really true and works ..
Intel P4 2.47 ghz with 1 MB L2 cache-HIS 845GVM mobo
512 MB DDR RAM .
Gainward 6600 gt golden sample edition(ultra 1960xp)
80 GB Seagate Barracuda 7200 rpm HDD
Sony QW -120A Dual Layer DVD writer.
go_gamez is offline
- by gohan89
