Old 26-06-2006, 10:18 PM   #1 (permalink)
tukaibatman
Posts: n/a
Talking Backing up movies!!!!!!!!!
hey this is a cute little atsk for people around here
I have got a small collection of movies but which are very dear to me
Digit says we can backup once
So I ask you how to do it but on a DVD
Also I want to know How to make it complete with a menu (as there will be more than one movie on a DVD)
Also the menu structure of the original CDs should be preserved
Is this legal and if it is I want an answer
Is Windows Movie Maker a good software to do this
Old 27-06-2006, 07:53 AM   #2 (permalink)
nishant_nms's Avatar
Default Re: Backing up movies!!!!!!!!!
use DVD descrypter for backing up ur DVDs
nishant_nms is offline
Old 27-06-2006, 08:01 AM   #3 (permalink)
TechGuru#1's Avatar
Exclamation Re: Backing up movies!!!!!!!!!
If U use Use DVD Decrypter,u MIGHT have problems burning that BACKUP by NERO Burning Rom!
Best is to Backup DVDs(on HDD) by Nero only,.....& l8r on,no problems with burning that Movie PROPERLY by NERO(...if u use NERO i mean).I do that !
TechGuru#1 is offline
Old 27-06-2006, 09:23 AM   #4 (permalink)
tukaibatman
Posts: n/a
None of you answered my question wholly
I want the whole process to be explained
The mods help me please
Old 27-06-2006, 10:27 AM   #5 (permalink)
plsoft's Avatar
Please make it clear whether yur movies are in CDs or DVDs.
plsoft is offline
Old 27-06-2006, 04:38 PM   #6 (permalink)
ax3
Cool as a CUCUMBAR ! ! !
ax3's Avatar
its really pain in the heart when ur fav original mov collection REFUSES 2 play or skips ur fav scene ...
y cant v have a permanent storage or skip proof cds/dvds ???
4 that thing i have stopped BUYING ORIGINAL MOVIE CD/DVD`s ... here`s where piracy takes its toll ...
ax3 is offline
Old 27-06-2006, 04:54 PM   #7 (permalink)
Learner
Kniwor's Avatar
it seems u have vcd's for the movies and u wnt backup on a DVD.
If u have nero premium then it's easy... just drag n drop the movies in nero vision and it will make menus n all automatically...
windows movie makes is not a good software as far as video editing is concerned... it's just basic
Kniwor is offline
Old 27-06-2006, 05:57 PM   #8 (permalink)
tukaibatman
Posts: n/a
Thanx Kniwor you understood my problem correctly
keep posting if there is a better solution
Old 28-06-2006, 10:18 AM   #9 (permalink)
9437077259
go4saket's Avatar
Seach the tutorial section for this... Anyways, for your convinence, here is the link...
Guide : Copy DVD Movies Without Any Errors !!!
As for menus, I am very soon going to update my guide for it...
Win 7 Ultimate
Abit IP35-E Mobo,C2Q 6600,4GB DDR2 RAM,XFX 8600GT 256MB DDR3 Gfx ,Seagate 1TB HDD,Sony DVD RW,500w SMPS,19" Viewsonic VX922 TFT,Logtech G5 Mouse,Altec Lancing 2:1 Speakers.
go4saket is offline
- by gohan89
