I cannot delete the following two application files in any way. What program should I use?
C:\WINDOWS\SHELLNEW\bronstab.exe
C:\Documents and Settings\ICA\Local Settings\Application Data\smss.exe
I agree with Vishal, do download a good antivirus software and boot to safe mode and do a full scan, delete anything that is detected. Turn off system restore before scanning....
Re: Cannot delete..help!!!
u can also delete in this way
open task manager
click on processes
then sort by user name
then end all the processes except explorer.exe and taskmgr.exe
then try deleting the file
also run a antivirus scan with a good antivirus or
use the quick remove utilities that vishal mentioned above......
open task manager
click on processes
IMO, you should be successful with this method. I have always done so whenever I have come across a file that stubbornly refuses to get deleted.
