Old 22-11-2004, 09:49 PM   #1 (permalink)
NikhilVerma's Avatar
Default "MSDOS compatibility mode file system" problem...
Dudes!
I have a problem... I recently upgraded my machine to
P4 2.8 Ghz
256 MB RAM
40 GB Samsung HDD
Intel 865GBF Motherboard
The problem is this...
My system is using MS-DOS compatibility mode file system.. Which makes games load very slow...
I am using Windows ME.
* The problem only started after I upgraded my machine..
* The problem was there even after a fresh Install of Windows ME ..
So I won't post my HijackThis log file for better assesment of the problem
* This problem ain't present in Windows XP
* I tried to download the latest drivers... But there were none.
NikhilVerma is offline
Old 22-11-2004, 10:08 PM   #2 (permalink)
See if this helps : http://support.microsoft.com/default...b;en-us;130179
game_dev is offline
Old 22-11-2004, 10:52 PM   #3 (permalink)
King of my own Castle
freshseasons's Avatar
Nikhil why are you stuck with windows Me since last 2 Years...Please can you tell us...As far as i know Windows Me is said to be most Sucking OS by Both DIGIT and Chips india.
Anyway...
Help is here :
http://asia.cnet.com/enterprise/apps...9084405,00.htm
Try that...or I have other better option !!!
freshseasons is offline
Old 23-11-2004, 06:55 PM   #4 (permalink)
Didn't work mate...
* I don't have any such NOIDE reg value
* My device manager shows no harddrives in the "Disk Drive" panel but it only shows 'em on the "Hard Disk Controllers" panel
Old 23-11-2004, 08:25 PM   #5 (permalink)
There is a resource conflict between the hard disk controller and another hardware device...may be..
The Windows protected-mode driver is missing or damaged.
The Windows 95-32-bit protected-mode disk drivers detcted an unsupportable configuration or incompatible hardware.
Now Try this too....
Download the Remideup.exe from here
http://www.dictacomm.com/95HELP/ide_drive.htm
In Windows Explorer, double-click the Remideup.exe file you downloaded in step 1
Follow the instructions on the screen
Please tell weather this helped....
Best luck Nikhil
Old 23-11-2004, 10:51 PM   #6 (permalink)
Hey I downloaded the file...
But It worsened the problems...!!!
Now I can't read my CD Drive....
Old 23-11-2004, 11:09 PM   #7 (permalink)
Read the page on the link given above by me properly. I think it has the solution to your problem without any download reqd.
All the best !
game_dev is offline
- by gohan89
