LinkBack (2) Thread Tools Search this Thread Display Modes
Old 22-11-2004, 04:03 PM   2 links from elsewhere to this Post. Click to view. #1 (permalink)
Default Samsung SP0411N
Samsung SP0411N Hard Drive displays only 31 GB instead of originally 40GB in WINXP and Bios. However I have one digital hard drive of 40 GB also whose size is correctly displayed by Bios. Pl. help me so that correct size is displayed.
rajivs007 is offline
Old 22-11-2004, 08:22 PM   #2 (permalink)
busyanuj's Avatar
check the hard disk jumper. you might have set it wrongly.
busyanuj is offline
Old 23-11-2004, 09:26 AM   #3 (permalink)
I have made my digital hard disk as primary master and Sansung SP0411N as primary slave. What are other jumper's pl. clarify.
Old 24-11-2004, 09:48 AM   #4 (permalink)
darklord's Avatar
if you want to configure that drive as slave,just remove the jumpers.That's all.
If the jumper was set to 'limit to 32GB' then after making slave i.e removing all jumpers,the partitions will get corrupted.As partition tables are screwed
darklord is offline
Old 24-11-2004, 10:11 AM   #5 (permalink)
No one is getting my point. I will explain in detail .........
I have two hard disks. One is of Western Digital corporation (WDC) and second one is Samsung SP4011N. WDC is configured as master by shorting the jumper settings of master drive and Samsung Drive is set as slave by removing all the jumpers. The issue is that though both drives are of 40 GB, WDC is showing 37.6 GB free space and Samsung is showing only 31 GB as free space. Why this is happening. I also asked this question to Samsung Customer Care but you know stupids are sitting there.
Old 24-11-2004, 01:04 PM   #6 (permalink)
did u look up the jumper table on the hdd ?
does NO JUMPER mean slave ? make sure of that first and let us know
all samsung drives dont have common jumper settings ... some use 2 jumpers as well
therefore check ur diagram and let us know ..
No Mercy, No Limits.
theraven is offline
Old 24-11-2004, 01:10 PM   #7 (permalink)
unless ofcourse u have a motherboard that doesnt support over 32 gb which i just realised
post ur config here
theraven is offline
Old 24-11-2004, 01:29 PM   #8 (permalink)
Ok I will check my jumper settings (First tell me how does jumper settings effect the size of my hard disk ). I have an ASROCK Motherboad P4i65GV.
http://www.asrockamerica.com/Products/P4i45GV%20R5.htm
Old 24-11-2004, 11:22 PM   #9 (permalink)
well there is a jumper settin to limit ur hdd size to a particular limit depending on the hdd
if u dun wanna use all of ur hdd
the JUMPERS are meagrely shorting 2 pins ... what happens is inside the disk
the internal cicuitry restricts access to the remainin 8 gb in this case when the particular pins are shorted
anyways its not ur mobo problem ... im quite convinced of that. ..
i can only see a jumper problem
if i think of anything else ill post. ..
do let us knwo if anything works
theraven is offline
Old 25-11-2004, 10:52 AM   #10 (permalink)
In many HDDs there are two jumpers.One for master/slave config and the other for restricting the HDD to a certain GB(e.g. 32 GB). Check the documentation which came along with the disk or simply see the label sticking upon it. I am sure the jumper settings must be clearly mentioned.
Quote-SP1: I think…….therefore I am……..I think.
wise is offline
LinkBack to this Thread: http://www.thinkdigit.com/forum/qna-read-only/3082-samsung-sp0411n.html
Samsung SP0411N - bookmark details This thread Refback 23-06-2011 08:15 AM
Samsung SP0411N Reviews Question This thread Refback 13-09-2010 07:38 PM
- by gohan89
