Old 22-06-2006, 09:27 AM   #1 (permalink)
Angry IP address confliction problem
i am using sify internet,
for 1 week i m getting IP ADDRESS CONFLICTION PROBLEM message , when this message appears i can't connect to net , I think some one is hacking my system Is there any software r technique to get rid off this problem
ambati is offline
Old 22-06-2006, 09:33 AM   #2 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
Default Re: IP address confliction problem
use a good firewall, antivirus and spyremover
Rollercoaster is offline
Old 22-06-2006, 09:55 AM   #3 (permalink)
Beware of the innocent
ilugd's Avatar
do you have a hardcoded ip address?
which os do you have by the way?
The error is due to the fact that there is another system on the sify network is having the same ip address. Each computer on the network has to have a unique ip. Since yours is trying to duplicate the ip, your box doesn't connect on the network. If you ip is not being assigned dynamically, or even if it is, you may need to contact customer care and tell them your problem. They will be giving you instructions.
ilugd is offline
Old 22-06-2006, 11:57 AM   #4 (permalink)
tuxfan's Avatar
Have you paid for a dedicated IP? If not, you can't have a hard-coded IP. Your IP must be dynamically assigned each time you connect. ilugd is pretty right in what he said.
tuxfan is offline
Old 22-06-2006, 09:18 PM   #5 (permalink)
\/endett/\'s Avatar
In sify, private ip is static and public ip is dynamic.
BTW, how much do u have to pay for dedicated connection? And what speeds do u get?
Thx.
~"Computers are useless. They can only give you answers."~
\/endett/\ is offline
Old 22-06-2006, 10:04 PM   #6 (permalink)
JGuru's Avatar
Use ZoneAlarm firewall and also use Norton antivirus software. Other antiviruses
have compatibility problem with ZoneAlarm. Tell me whether yours is static or
dynamic IP? Always use dynamic IP , not static IP. This should solve your problem.
JGuru is offline
Old 23-06-2006, 01:01 AM   #7 (permalink)
__Virus__'s Avatar
how and why is firewall or antivirus coming into picture of IP conflict as tux and ilugd already explained you the reason.. call up sify and inform them about the ip conflict.. they very well have the information about what ip to whom
__Virus__ is offline
- by gohan89
