Old 21-11-2004, 07:44 PM   #1 (permalink)
Posts: n/a
Default personel web server fro php.
hiii .. can anyone tell me how can i use my php pages on my pc on the lan . i have just down loaded phpbb forum code from net and i want to use it in the lan . whick king of database i should use for that . can u give me some detailed info about php and that coz i m less familiar with the php ..
Old 21-11-2004, 07:53 PM   #2 (permalink)
tuXian's Avatar
I think MySQL - nearly all forums run on it
You know it's love when you memorize her IP to skip DNS overhead.
tuXian is offline
Old 21-11-2004, 07:55 PM   #3 (permalink)
Posts: n/a
ok i have my sql . but how to run forum on lan ?
Old 21-11-2004, 08:11 PM   #4 (permalink)
LAN? or ur PC??? I am kinda confused. Neither you have mentioned what OS you are on. I assume you are on windows and wnat to run php server pages locally. Download phpdev from sourceforge.net/projects/phpdev5/ and read the manual. install phpbb in www directory and you are set. I recommend reading manual. Best of luck.
Bother no one. If someone bothers you, ask him to stop. If he does not stop, destroy him.
Visit: http://bodybuilding.name/
diab0lic666 is offline
Old 21-11-2004, 09:28 PM   #5 (permalink)
Use either Apache/Tomcat server dude..
SmoothCriminal is offline
Old 21-11-2004, 10:02 PM   #6 (permalink)
alib_i's Avatar
Default Re: personel web server fro php.
You need to install php ..
and you need MySQL database..
see this link .. i'll asnwer most of the questions
http://internetmaster.com/installtutorial/
-Metallica
alib_i is offline
Old 22-11-2004, 12:23 AM   #7 (permalink)
din
Tribal Boy
din's Avatar
The BEST thing available in internet in my opinion is
http://www.apachefriends.org/en/
U will get
Apache, MySQL, PHP + PEAR, Perl, mod_php, mod_perl, mod_ssl, OpenSSL, phpMyAdmin, Webalizer, Mercury Mail Transport System for Win32 and NetWare Systems v3.32, JpGraph, FileZilla FTP Server, mcrypt, Turck MMCache, SQLite, and WEB-DAV + mod_auth_mysql.
as a single exe !! ( thers file for linux system too )
Its very easy to install and run . I strongly recommend it . Its FREE
din is offline
Old 22-11-2004, 12:47 PM   #8 (permalink)
Posts: n/a
thanx a lot . and i m using win xp as os . i have downloaded badblue personel web server from net and now i will try now i m down loading the file mentioned by DIN . and to diab0lic666 i want to set up for lan
- by gohan89
