hi,
none of the software allows us to boot from a cd and restore. i mean the CD which has the hard disk image, so boot from the cd, a simple interface, which will ask do u really want to restore, say yes. your partition is recovered from the image.
using ghost or acronis, u hav to make a boot cd of theirs like boot from the cd then select the partition then search for the image...... Sometimes you may have to use PE cd (eg, Bart PE)..
Just in case someone finds a s/w the way i want it, plz let me know.
Paragon system recovery, this s/w does it, have a visit :
http://psr.paragon-software.com/
thanks
