Old 21-06-2006, 07:08 PM   #1 (permalink)
Default Automatic Power on and Shutdown
hey guys ,
how can i schedule my Pc for auto power on , i use a ASUS Bios which does not support auto power on . I can get some software for automatic shutdown .....but i havent found any solution for automatic power on from shutdown state.....can anybody help me out??
deadly_dude is offline
Old 21-06-2006, 09:43 PM   #2 (permalink)
ayush_chh's Avatar
Default Re: Automatic Power on and Shutdown
never heard of any software for Auto power on......
thinking on it......
is it possible.......if ur system is off....how can a software run????????
ayush_chh is offline
Old 22-06-2006, 12:29 AM   #3 (permalink)
shovik's Avatar
auto power on is not supported by any current peripherals, but you can do auto-shutoffs by using timer softwares.
shovik is offline
Old 22-06-2006, 05:40 PM   #4 (permalink)
Try auto power on & shutdown software. You have to place your system in hibernate state for the software to work.
troubleshooter is offline
Old 23-06-2006, 12:10 AM   #5 (permalink)
JGuru's Avatar
That's right. If you put your System in hibernate mode , then the software can
auto power-on. Auto-shutdown can be done by creating a task to Shutdown,
and adding it to the task-scheduler. Do remember that hibernate mode consumes
a little power!!
JGuru is offline
Old 23-06-2006, 08:04 AM   #6 (permalink)
The pWnster
Vyasram's Avatar
It is poossible if u hav electricity supply
Go to bios>Power mgmt(or similar stuff)>APM(auto power on or mgmt)
Enable power on by rtc alarm/alarm
Select the day(s) u wanna boot ur pc automatically.
Done, make sure u dont switch off the electricity source
Sigs suck
Vyasram is offline
Old 23-06-2006, 11:02 AM   #7 (permalink)
Commander in Chief
QwertyManiac's Avatar
Am not sure but does APC UPS service have some stuff on auto power on in case its connected to the PC via a serial cable? I am just guessing, not sure as I said before.
Harsh J
www.harshj.com
QwertyManiac is offline
Old 23-06-2006, 12:00 PM   #8 (permalink)
but as i said before ......i use a ASUS BIOS ....which doesnt have a auto power on feature in it ....and auto power on and shutdown software is a trialware which i already used up......isnt there any other software like Auto power on and shut down??
- by gohan89
