Old 21-06-2006, 06:43 AM   #1 (permalink)
56561's Avatar
Cool tell me how to make these changes ( dsktop enhance)
well I want an exact tutorial , the problem is very simple if u know which software and how to use but I am not getting . so asking your help .
how I can change this tell me how to make these changes ( dsktop enhance)-digit1.jpg
to this
now just dont tell me use this software and goal . u have to tell me how to do that also . I am a very green hand . thanks in adv .
56561 is offline
Old 21-06-2006, 07:16 AM   #2 (permalink)
Default Re: tell me how to make these changes ( dsktop enhance)
install vista inspritation package .
thats it , isnt it cool .
hermit is offline
Old 21-06-2006, 08:41 AM   #3 (permalink)
I think thats come default on windows vista , will it run on XP ? i dont know , perhaps some desktop enhancement software can do the same .
ask those guys who do desktop enhancements .
by the way what is this "vista inspritation package" ?
reddragon is offline
Old 21-06-2006, 09:08 AM   #4 (permalink)
Commander in Chief
QwertyManiac's Avatar
For an easy way... go to CrystalXP.net and download the Vista Inspirational Pack. Or the Vista Transformatin Pack via Softpedia.
For the harder way (no tutz0rs) use ResHack/StyleBuilder/Other stardock products...
Harsh J
www.harshj.com
QwertyManiac is offline
Old 21-06-2006, 11:06 AM   #5 (permalink)
18 Till I Die............
You can ask Vishal Gupta at his thread on How to modify files using resource hacker running in the Tutorial Section. He may help. But, don't expect it soon as he's on a study break as of now.
Here's the link to his post TUTORIAL: List of Files to be hacked using Resource Hacker!
mehulved is offline
Old 21-06-2006, 11:48 AM   #6 (permalink)
The Researcher
Vista Transformation Pack works in win xp. It is free. I am now downloading it.
Ramakrishnan is offline
Old 21-06-2006, 12:15 PM   #7 (permalink)
JGuru's Avatar
Yeah. I t works well in XP. These are just transformation packs that change the
default Windows XP icons to Vista icons. Your System may report that some files
have changed , please insert the Windows XP CD to correct it. Click the 'Cancel'
button. The overall effect is nice , but there are some minor problems like, some
applications still look like XP applications, rather than Vista!!
JGuru is offline
Old 21-06-2006, 01:49 PM   #8 (permalink)
the deconstructionist's Avatar
The easiest is object dock and use yahoo tweaks.
Welcome to the desert of the Real...
" ಡ್. ರಾಜ ಅಭಿಮಾನಿ "
the deconstructionist is offline
Old 21-06-2006, 08:18 PM   #9 (permalink)
56561's Avatar
noone is giving an exact tutorial huh
i only want to change the start menu ..........now tell me the procedure
Last edited by mehulved; 21-06-2006 at 09:17 PM. Reason: two consective posts where one could have done
56561 is offline
Old 21-06-2006, 11:13 PM   #10 (permalink)
56561's Avatar
@Indyan u r right ...............totally true ...........so tell me how to do the "Second one" i never found the vista theme from kol . KOL deleted it from deviantart
56561 is offline
Old 22-06-2006, 10:56 AM   #11 (permalink)
dOm1naTOr's Avatar
Try Talisman....Its really great..It give us a feeling of a NEW WINDOWS or somethin other..
G3: XPS M1530 |
FZ 16.
dOm1naTOr is offline
Old 22-06-2006, 11:56 PM   #12 (permalink)
for ur pblm.. 1 of the many solutions is tat u install the visual themes available on www.themexp.org n the details wil b given to u once u download frm thre.. chek it out.. its damn gud!!
alienspiesu is offline
Old 23-06-2006, 12:01 AM   #13 (permalink)
Commander in Chief
themexp.org bundles spyware/adware, avoid it please... i has DOTNET eek! use Deviantart.com instead...
Harsh J
www.harshj.com
- by gohan89
