Results 1 to 6 of 6
Thread: Where is xine?
21-11-2004, 03:22 PM #1Right Off the Assembly Line
- Join Date
- Mar 2004
- Posts
- 15
Where is xine?
I installed Xine in Mandrake Linux 9.1. Now I dont know how to open xine. Where the linux software will get installed? What is the exe file for linux.
21-11-2004, 03:46 PM #2Alpha Geek
- Join Date
- Dec 2003
- Posts
- 780
Linux doesn't have .exe files though files may be given executable rights ... anyway look in /usr/local, /usr/local/share & /usr/share you may find it. To run it type ./filename
BTW, you installed it using RPM? If so most graphical rpm managers show the list of the files installed by the RPM & where they are installedHardware - Celeron 266 MHz, 128MB RAM, Intel i740 8MB RAM
Software - Slackware Linux 10.1; Archlinux 0.7; Windows 98 SE
Humanware - GS/CS C++ L+++ w b+++ DI+ D+ e
22-11-2004, 01:51 PM #3
ujjwal told you everything... however you can give this command to find the location of xine.
$ which xine
to run xine, just open the run dialog or a terminal and type xine- --
http://web.gnuer.org
25-11-2004, 02:43 PM #4Broken In
- Join Date
- Sep 2004
- Location
- Online
- Posts
- 106
I WANT TO KNOW HOW CAN I SHORTCUT OF XINE/XMMS ON MY DESKTOP?
Education... has produced a vast population able to read but unable to distinguish what is worth reading
25-11-2004, 08:06 PM #5
create a shortcut by right-clicking on your desktop.... in the target link give the path that you get after you execute $ which xine ...
you can also add a custom pixmap to it !- --
26-11-2004, 06:35 PM #6
I think most of the softwares get installed in /usr/bin
xine demuxer problem
By phreak0ut in forum Open SourceReplies: 16Last Post: 01-12-2006, 10:45 PM -
xine not installing properly...
By prashanthmpai in forum Open SourceReplies: 24Last Post: 25-11-2005, 09:40 PM -
How to install xine on Fedora Core 3!
By curvenger in forum Open SourceReplies: 19Last Post: 11-06-2005, 08:28 AM
LinkBack URL
About LinkBacks
