Old 20-06-2006, 03:55 PM   #1 (permalink)
linardni's Avatar
Default System Registry Locked
I cannot enter the system registry of my PC running Win XP. Message popping up that it's locked by the administrator. What to do?
linardni is offline
Old 20-06-2006, 05:47 PM   #2 (permalink)
Default Re: System Registry Locked
Go to Start and Select Run and type gpedit.msc
Select Administrative Templates under User Configuration.
Select System and on the right side SELECT Prevent access to registry editing tools and double click it to enable it and select NO under Disable regedit from running silently.
tonic4u is offline
Old 20-06-2006, 08:45 PM   #3 (permalink)
__Virus__'s Avatar
also u may want to try this command from command prompt once ur logged as Admin
REG add HKCU\Software\Microsoft\Windows\CurrentVersion\Pol icies\System /v DisableRegistryTools /t REG_DWORD /d 0 /f
it did work for me
__Virus__ is offline
- by gohan89
