Old 19-06-2006, 06:46 PM   #1 (permalink)
Default LIMEWIRE is safe ?
After installing limeware.......pestpatrol i have detected its is low grade threat and at same time it has detected.......kazza and another p2p .......Grokster
which i never installed........from where i got this one....?
http://img233.imageshack.us/img233/1479/lm8we.jpg
http://img235.imageshack.us/img235/6833/ljjjmm1br.jpg
mkmkmk is offline
Old 19-06-2006, 06:57 PM   #2 (permalink)
Default Re: LIMEWIRE is safe ?
thanks........
but why i got kazza and Grokster.....along with limewire.......is it too normal ?
mkmkmk is offline
Old 19-06-2006, 07:01 PM   #3 (permalink)
The Devil's Advocate
iMav's Avatar
if ur using limewire always check the file size ... never download any file with the size of 134 kb and 85.7 (not sure something in the 80s) they are viruses i royally screwed my machine and according 2 pestpatrol every limewire file is faulty so if ur using pestpatrol do not delete any file of limewire its of no use !!!
http://beingmanan.com
iMav is offline
Old 20-06-2006, 12:19 AM   #4 (permalink)
__Virus__'s Avatar
I used to use Limewire but after using Bearshare for a while am completely satisfied with the downloads it does continuously... but the thing that puts me off??? lots of unwanted porn
__Virus__ is offline
Old 20-06-2006, 11:53 AM   #5 (permalink)
aryayush's Avatar
Doesn't BearShare crash a lot? I used to use BearShare but it used to crash and get uninstalled from my system so often that I had to uninstall it finally.
aryayush is offline
Old 20-06-2006, 12:12 PM   #6 (permalink)
dattebayo
anispace's Avatar
its 851.7KB i think. those files are all viruses.
Yoda: No. Try not. Do... or do not. There is no try.
anispace is offline
Old 20-06-2006, 08:49 PM   #7 (permalink)
__Virus__'s Avatar
lemme clear myself if I was not last time... I use bearshare pro and its up and running from past 15 days without crashing
Old 20-06-2006, 09:13 PM   #8 (permalink)
aryayush's Avatar
I also had BearShare Pro. Do you have ZoneAlarm or any other firewall installed?
aryayush is offline
Old 21-06-2006, 05:08 AM   #9 (permalink)
thunderbird.117
Posts: n/a
Lime-Wire is good. The pro version does not have any adware or spyware. Almost all freeware has those.
Old 21-06-2006, 07:21 AM   #10 (permalink)
always remember p2p is always at u r risk
u need to use good antivirus and anti-spywares and trojan removers .
i dont prefer p2p at all u will get evry think on forums then y p2p ?
hermit is offline
Old 21-06-2006, 12:27 PM   #11 (permalink)
JGuru's Avatar
If you use any P2P software , you are at risk . Because whatever files your peer (other person) has be it pics, MP3, Videos etc., this harddisk may also contain
some worms, trojans, viruses. It may get transferred to your PC!!
Always use a good firewall like ZoneAlarm. Use Norton antivirus also.
JGuru is offline
- by gohan89
