Old 19-06-2006, 03:33 PM   #1 (permalink)
Default Delete NTFS Protected Folder
This morning I ran Windows Update (on my Win XP SP2 system) (My Biggest Mistake)
Now I cant boot into it, neither safe mode, nor last good config, nothing works. After th Initial Splash screen, screen goes blank and nothing happens.
Then I tried repairing my OS thru the XP CD, this too hangs. (System Restore was already disabled, so I cant restore.)
So I installed it on another drive. (Gr8, it got installed).
Then I copied the data frm C drive (which had OS initially) using GetBackData for NTFS. But how do I remove those user folders in "Document & Settings".
Please suggest a way to either revive the previous XP Installation (most preferrable) or any utlitiy to delete these NTFS protected folder.
enjoy is offline
Old 22-06-2006, 06:02 AM   #2 (permalink)
Default Re: Delete NTFS Protected Folder
Guys I solved the issue using this article. Thanks anyways.
To Take Ownership of a NTFS Protected Folder
http://support.microsoft.com/default...;en-us;q308421
enjoy is offline
- by gohan89
