Old 21-11-2004, 12:31 PM   #1 (permalink)
h4ck3r
Posts: n/a
Default A general QUESTION - Tough i guess ??
A General question to all of you. How will make your computer End the application automatically ?? (instead of manual "EndTask" using CTRL+ALT+DEL) Well if you know how, pls reply here
For Windows 98 only
For Xp there is a solution
This question will test your skills in windowz
Old 21-11-2004, 01:08 PM   #2 (permalink)
vysakh's Avatar
dont click end task. press alt-E
Incompatible message format
vysakh is offline
Old 21-11-2004, 01:12 PM   #3 (permalink)
h4ck3r
Posts: n/a
Default Yo got it wrong
Not the shortcut or ctrl +alt+ del .We should make the pc do things on its own without using the shortcut keys but the "not responding" program should end by itself...Did you get the question mr.
and pls read the post thoroughly bfore replying..I know the anser but i wanna let the others know
Old 21-11-2004, 03:15 PM   #4 (permalink)
Some time back I had installed a tweaking utility which allowed configuration, where Non-responding processes/programs would get killed automatically after a specified time. I will go through it again and get the answer.
BTW, I have forgotten the name of the tweaking program. :roll:
Eager_Beever is offline
Old 21-11-2004, 04:48 PM   #5 (permalink)
aadipa's Avatar
SwitchOff will tel u do it
1 aadi + 1 aadi = 1 full ;)
aadipa is offline
Old 21-11-2004, 04:49 PM   #6 (permalink)
I had used tis for a while 12ghost shutdown
It used to do the stuff 4 me.
beyondthegracefgod is offline
Old 21-11-2004, 10:40 PM   #7 (permalink)
alib_i's Avatar
no third party softies reqd
Open the registry and find the key below.
Modify the value of 'AutoEndTasks' to equal '1' to automatically end tasks or '0' to prompt for action.
The default time-out before ending the task is defined by the value of 'WaitToKillAppTimeout' located in the same key, this value is in milliseconds (default = 20000 i.e. 20 seconds). You can therefore additionally change this value to speed the process up.
Note: This change will affect all users but value can also be changed on a user-by-user basis by modifying [HKEY_CURRENT_USER\Control Panel\Desktop] and the same values.
Key:[HKEY_USERS\.DEFAULT\Control Panel\Desktop]
Value Name: AutoEndTasks
Data Type: REG_SZ
Data0 = disabled, 1 = enabled)
source http://www.mydesktophelp.com/tips/win10.htm
-Metallica
alib_i is offline
Old 22-11-2004, 01:16 AM   #8 (permalink)
Hats off to alib_i!
SmoothCriminal is offline
Old 25-11-2004, 01:35 AM   #9 (permalink)
cowboy hats off!
lamrinnirmal is offline
Old 25-11-2004, 06:04 AM   #10 (permalink)
alib_i's Avatar
thnx
-Metallica
alib_i is offline
Old 25-11-2004, 06:18 AM   #11 (permalink)
The Photoshop Guy
cooljeba's Avatar
cool one alib_i
BTW just press the fu****g power button dat will do the trick no matter what OS u have kiddin'
..:: peace ::..
Jeba
cooljeba is offline
Old 25-11-2004, 12:31 PM   #12 (permalink)
simple alt+f4
sheladiya chetan
chetan is offline
Old 25-11-2004, 09:02 PM   #13 (permalink)
mariner's Avatar
good one ali_bi
mariner is offline
Old 25-11-2004, 11:12 PM   #14 (permalink)
dude ... cool stuff
n grt link too
talrejaharish is offline
Old 26-11-2004, 11:35 AM   #15 (permalink)
For those who dont want to do registry editing, I had made a small program (8 kb) for this, long ago. (Applies around 8-10 reg tweaks)
It not only enables auto-end task your programs, but also speeds up your shutdown/restart considerably. It also solves most common problems that occur while shutdown/restart.
Works in all Windows versions (above 95):
http://www.free-webspace.biz/dexter/FastShut.exe
_________________
Firefox
Rediscover the web
Yes, I\'m back. Not 24x7 yet, but pretty soon.
Please be a bit considerate (don\'t bombard me with PMs and all) as I need to some time to Synchronize my brain with the forum.
Any inconvenience caused is regretted.
[deXter] is offline
Old 26-11-2004, 02:31 PM   #16 (permalink)
Originally Posted by [deXter
]For those who dont want to do registry editing, I had made a small program (8 kb) for this, long ago. (Applies around 8-10 reg tweaks)
I got this error when I ran FastShut.exe in Windows XP with SP2
Whatever happens, happens for good!
ramank is offline
Old 26-11-2004, 03:17 PM   #17 (permalink)
Well you have a corrupted download. For your convenience I have RARed it up too:
http://www.free-webspace.biz/dexter/FastShut.rar
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 26-11-2004, 03:49 PM   #18 (permalink)
Thnx [deXter], my computer will now shutdown/restart/logoff properly, and instantly!
BTW, who is Dilton?
ramank is offline
Old 26-11-2004, 04:36 PM   #19 (permalink)
Well thats my other nick. I was called Dilton ages ago even before my friends named my dex.. Actually my Mom used to call me Dilton
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 26-11-2004, 05:39 PM   #20 (permalink)
Hey [deXter].
Your avatar is tooo small now.
The rules....
Simple things are to simple too understand.
Prashray is offline
Old 26-11-2004, 06:50 PM   #21 (permalink)
Well actually I've seen a few ppl on this board with similar sized avatars (for eg: deep) so I thought lemme try this on for size
Or would you rather I use this monochrome-old-nokia style avatar ?
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 26-11-2004, 07:57 PM   #22 (permalink)
Well I thought of going mono.. Which one of these do you think is better?
_________________
Firefox
Rediscover the web
[deXter] is offline
Old 27-11-2004, 11:22 AM   #23 (permalink)
Bewitched!
xenkatesh's Avatar
NIce dexter!! hats off to alib_i
Keep your friends close and enemy CLOSER!!!
Ragnarok Online: One World, One Million Possibilities.. :)
xenkatesh is offline
Old 27-11-2004, 07:10 PM   #24 (permalink)
alib_i's Avatar
thnx xent ...
@ dex .. the 1st one is best
-Metallica
alib_i is offline
- by gohan89
