Old 18-06-2006, 08:14 PM   #1 (permalink)
jamyang312's Avatar
Post get beats without vocals in a song
how do i get only the beats without the vocals in a song?
think u will never see the devil?
look in the mirror and u will see one!
jamyang312 is offline
Old 19-06-2006, 12:54 PM   #2 (permalink)
jamyang312's Avatar
Default Re: beats in songs
plz help it's important!!
Old 19-06-2006, 01:22 PM   #3 (permalink)
shovik's Avatar
use beatmaster or beatcraft to select the range of bitrate for ur file and then select low frequencies for encoding of ur audio file
shovik is offline
Old 19-06-2006, 01:23 PM   #4 (permalink)
-The BlacKCoaT Operative-
Rollercoaster's Avatar
there areplugins for winamp at their site search there
BTW the result is not at all good when u remove vocals from a song as they use channel canceling...
better to find the source music somewere if u can.. all songs are recorded on multiple tracks like vocals + beats + guitar etc but they are not easy to find. only a friend at the recording studio can help
Rollercoaster is offline
Old 20-06-2006, 11:48 AM   #5 (permalink)
Going green anyone?
qarch's Avatar
You are talking about karaoke (songs without the vocals)! Or making a karaoke version of the song you want. There are a number of free karaoke software out there. Google for it.
qarch is offline
Old 20-06-2006, 06:44 PM   #6 (permalink)
try goldwave, use the reduce vocals feature. You might not get so good edit but, it works for certain tracks.
www.Solinweb.net - Webhosting was never so cheap in India!
www.cyclone2k.net - More than wrestling....
www.myspacery.com - Myspace Layouts, Myspace Codes, Myspace Generators, Myspace Tweaks
thecyclone2k is offline
- by gohan89
